wiring to E4OD
The problem here is trying to tie the headlight to the engine dieing.
However he wired the sensor should not have let the engine run and then die when the headlights are turn on.
It sounds to me as if the computer grounds at the body ground are getting their ground through the headlight bulb and back to the NEG post of the battery. When the lights are turned on you kill that ground and then the computer has no ground and stops the spark and fuel.
Here is the only connection I can make that would do that is in the diagram below:
How bright are the headlights when you turn them on with engine running(till it stalls)? I don't think the headlights are being used as a ground. With the headlight switch off, the headlights will be floating on that switch(not grounded on power side). When the switch is on, power will flow through the switch and headlights through the ground connector.
Unless some wires gotten shorted together or mung up by previous owners. The problem is probly right where Bill has said.
Marketmanohyeah1
02-23-2014 01:08 PM
steve97601
08-25-2008 09:18 AM
