Straight axle swap
You can use a dana 60 out of an F350 of this vintage. But you're gonna want to use the 1 ton springs. Its best to buy a parts truck with a blown motor or something similar. Usually u can grab a whole truck for 1000 which is what the D60 is worth alone.
You could also use an axle from the late 70s (that's what I did) and the spring perches just need to be seperated a little bit.
But you'd need the steering components, suspension, and track bar as well as a complete axle for whichever you choose.
I believe the hangers are either in the same place, or the holes are there already.
yes everything from the pitman arm down.
on the late 70s axles, the perches are closer together pn the axle because the frames were narrower. You just have to torch off the existing mounts and weld perches a couple inches further apart.
77hiboyboy
03-22-2003 07:30 PM
