No way to tell it could have three times that on it. I have a couple of vehicals i have watched roll over three times and one is a 97 model. At least on the 97 it has all of the miles showing on the odometer ,the older ones just role over and become new vehicals again,L.O.L.
Someone told me that the numbers are crooked after they roll over. Is that not true?
As Jim said, no real way to know. Does it have a lot of wear and tear on it? Of course, I once had a truck that the original owner swore only had 85,000 miles on it, but it looked like a lot more than that due to sitting. On later model trucks, a CarFax report helps, but on the older ones, it is a lot harder to know for sure. Also, up here where I am from, 30,000 miles is like 150,000 to 200,000 due to conditions and the extreme cold (depending on if anyone did maintenance on them also, which often doesn't happen out here in rural Alaska).
A friend of mine that used to sell used cars told me a dead give-away to high miles is the brake pedal pad. If somebody claims low miles, but the pedal pad shows lots of wear, they're probably lying. Of course, pedal pads can be replaced, too.
Low miles and high wear on the brake pedal pad can show mostly city driving versus highway miles.
the gearing plays a big factor too,i just rolled over80000 but w/ the 4.11 gears im spinning 3000rpm at 60mph. putting alot more wear on the motor than 80000 miles w/ say 3.50 gearing. if standard tranny that will give away alot too, feels tight,no grinding,good indications. look around,there are tells everywhere
