MAF sensor
Assuming that yours is the same as mine (2003 F-350) , it is located just behind the air-filter in the housing.
1- You can unplug and remove the entire sensor (torx screws ) and spray CRC brand(?) MAF cleaner , let it air-dry and reassemble .
2- Short-cut : While MAF sensor is in place , just remove the air filter and the clamp of the air hose leading to throttle . Now you can spray it from both direction .
Remember :a- Remove (-)battery cable , just in case nothing is shorted,
b-Do not touch the wire with anything
c-Do not use anything but an MAF cleaner,
Good luck,
Good luck,
gman97005
10-25-2013 03:38 AM
