1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 06-08-2016, 04:57 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Originally Posted by MadMatt65
OK.....2nd trans in! Thank you Ford! No thanks to the local dealer!
New fuel pump, hanger and level installed! Thanks Bronco Graveyard!
A/C charged up (no leaks) and chilling!
Ive got a slight hesitation/miss just off idle. I thought it was the TPS because the wires looked lij they had been chewed on. I cleaned the throttle body and the AIC motor. Throttle body was nasty!
Still have the problem. No codes.
Any ideas?? EGR need cleaning too???
Anyway......Bronco is back on the road!!
Probably wouldn't hurt to check the EGR, although I don't know much about them. I don't have the experience and joys of dealing with one.
I'd also pop off the distributor cap and check the contacts and rotor. If they are worn out either clean em or replace em. Then maybe get a timing light and make sure the timing is still good?
Did you test the TPS at all or no?
  #3152
Old 06-08-2016, 07:54 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
No.....didn't test the TPS due to it having bare wires.
I'll test the EGR tomorrow at the shop. Just has an annoying miss hesitation just off idle while cruising or sitting.
  #3153
Old 06-08-2016, 10:52 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
I replaced an old clamp on the lower steering pump hose to stop a leak. Also stopped a pan leak on the trans drain. Replaced the bushings on the passenger side front wheel shocks... Boy that was fun...
  #3154
Old 06-08-2016, 11:11 PM
Bruners4's Avatar
Bruners4
Bruners4 is offline
Installed 6 new Bilstein 4600 shocks tonight after work. It still had the original shocks on it!
Last week I got the windows tinted. I'll have to get it cleaned up and take some pictures.
  #3155
Old 06-11-2016, 03:41 AM
scalladaballa's Avatar
scalladaballa
scalladaballa is offline
Replaced the high pressure fuel pump, fuel regulator, and ignition coil.
  #3156
Old 06-11-2016, 07:01 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
Moved it to cut grass @ 5:30 this morning. Bet the open headers woke ALOT of neighbors up.
  #3157
Old 06-11-2016, 08:56 AM
mountain dewd's Avatar
mountain dewd
mountain dewd is offline
Finally got around to replacing the blown radiator with a heavy duty unit.
  #3158
Old 06-11-2016, 08:04 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
Glad everyone else is enjoying their bronco.
Having stupid *** power steering hose issues.
  #3159
Old 06-15-2016, 04:09 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
Spent the last two days putting a factory transmission crossmember in the frame and putting the radius arm mounts on the drop brackets with new hardware and putting them back in.
  #3160
Old 06-15-2016, 05:21 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
new stereo and fuel filter in the 95 bronco. Oil change done on the 95 and 91 bronco.
Picked up a 4bbl intake for a 351W for free along with a C6 transmission with T-case plus some extra 351 parts all for free going to use a lot of it for my project 83 bronco.
Trav
  #3161
Old 06-18-2016, 05:32 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
I spent 3 hours today stripping parts off my parts Bronco. I got the dash wiring harness out, the dash out, all the heater ducting and heater box (since it's a non A/C rig), NP 205 torque mount off the frame, steering gearbox, rear half of the wiring, rear interior panel supports, and the rear arm rests. Still need to pull the core support, tailgate hardware (tailgate is shot and the internals were already gone), rear step bumper, and firewall. I may also pull some roof and floor metal for future patches on my Bronco. I know that I don't need all the parts I'm pulling, so once my Bronco is done I'll be selling what I don't need.
  #3162
Old 06-24-2016, 05:04 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
Went back to the donor and pulled the tailgate hinges, tail gate strikers from the body, rear floor body bolt covers, and some donor sheet metal pieces cut off. Too bad the last guy already had stripped the tailgate guts...
  #3163
Old 06-24-2016, 05:50 PM
MadMatt65's Avatar
MadMatt65
Cleaned the carbon off the EGR pintle. (Very nasty!) Going to eventually pull the intake and give it a good cleaning. Cleaning the EGR took care of my off idle miss and hesitation!
Got a new fan clutch. Driving it the other day and noticed the temp was gradually increasing while sitting. (More than I liked) Flushed the radiator the other day also. I topped off the coolant when I got it going.....I guess all that nasty corrosion from sitting all that time broke loose once I started driving it.
  #3164
Old 06-25-2016, 11:19 AM
MadMatt65's Avatar
MadMatt65
Just changed the fan clutch. Re-installed the serpentine belt......had it off 1 rib on the crank and smoked the belt!
Off to get another belt!
  #3165
Old 06-26-2016, 12:09 PM
MadMatt65's Avatar
MadMatt65
New serpentine belt on. Re-checked some of the vacuum lines I replaced. Found the lines going to the vacuum canister were reversed! Running pretty good! Curious why it wasn't setting any codes.
Hopefully, I can get the windows tinted next weekend.
Still have to order the seat covers from Marathon. Too expensive to redo the leather! Going to do the Kryptek Typhon pattern. Trying to find headliner material in that same pattern. (I think it will look good.)
Quick Reply: What did you do to the Bronco Today?
