What did you do to the Bronco Today?
#2222
I spent last 4 hours checking engine wiring and mapping it. Now I should be able to refer to my notes and know which pin any wire goes to on the fender connection (square '94 style) and which connection it fastens to at the EEC module ('90 F250, ZF, 5.8L) Should work with what I'm trying to do. Instead of a cross over pipe, I want to install 2 HEGO sensors. If I can find a wiring diagram for it. I know the '90 Mercury Gran Marquis used this with the 5.0L.
#2223
#2224
I was going to replace mine till I found the manifold cracked. It also gave me an excuse to install all new exhaust for my JBA headers!
#2225
I checked 3 stores and found a set at local NAPA store. Also bought a set of screw extractors to get broken bolts out, they are going back after work tommorow! Dug around in my tool box and found another that was correct size and it broke off tight in the bolt I was trying to remove. What a pain! !
1 hour and forty five minuets later I have one cleared and 2 more to go. I need to stop and get a few more of the tiny cone shaped stones for my Dremel, the one I had saved the day.
#2226
#2227
#2228
#2232
on
I got in mine to go an hour an a half to town. Battery dead. Son left the switch on the other day. So I charged it over night. It started. Today it
was dead again. So I figure I over charged it and killed the battery. I shut it off in town and had to get a jump start. So I figure the battery is toast.
It's a cheap green one and almost 5 years old. So in the morning I will put one of the three $200 battery's I bought for the big bus in it. Hell I could
prolly run the 70 or so miles to town on the starter with it. I am sure it's charging, Just not holding the charge. Such is life in the Bronco lane.
For what I payed for it and have had to put into it since i have had it, I am a
happy camper.
happy camper.
#2233
#2234
Well, I'm bringing TGM back to life. The battery is dead. Or low enough to prevent starting so I've got it charging now. After lunch I'll check. Once it's running I plan to let it warm up and make sure everything works like it should, the park it .
Tonight however, I want to drive it to work. There is a new girls and.. yeah, I haven't driven the bronco in close to 4-5 months. Despite the brakes being as bad as they are, I'll still hit the road. My work is a mile away so it's all fine.
