Transmission
That is most likely an E4OD transmission. There were only two automatic transmissions used for the 7.3 IDI. One was the C6 which only had 3 gears and the other is the 4 speed E4OD. If you have overdrive and a button either on the dash or on the shifter that is labeled O/D Off, you have an E4OD.
MJboy
08-15-2019 11:17 AM
Poorboy04
11-08-2013 01:27 PM
