the weekend...
the weekend...
welp finally got a vid uploaded... from big tire class..
cant really see it from the vid but it broke the U joint at the trans case on front drive shaft on the last hill
the front driveshaft connected with the transmission
it appears it split the pan only *crosses fingers*
anyways heres another pic of the truck...
Yup thats it... first pic you posted was on 35x16 Boggers rear was on 14" wide wheels and the front was on 12's, Second pic was when it still had the 38x12.50 Tsl's all the way around it and the last was in the middle of painting it right after i put the boggers on it
on that first pic on the 35's the truck has no lift, and has no fender trimming... then with the 38's the front had about 2" with the front fenders trimmer
Since its raining and i cant finsih getting the truck ready to take apart im surfing the interwebz...
Ive decided im tired of crushing the caps and ripping the ears off U joints, while im not going to switch over to bigger Joints, anyone know where i can get grease less U joints (with out the grease fittings) or just a lead on a little bit tougher ones than the PDQ that Advanded sell's my front Shaft is out of a F-250 and the way ive got it in there is backwards putting the 1330 end at the tcase, so the U joint that i keep busting is a 1310-1330 Joint, also its getting new U bolts on them as the ones on the transcase where slightly Effed up making it a pitta to tighten so it will be getting new ones there as i think that maybe part of the problem
im a fan of Precision's super strength Ujoints. They put the grease zerk in the end of a cap, instead of in the cross. Less drillings = stronger in theory. Ive twisted my driveshaft in 2, blew up the yoke at the axle, and blew up the slip shaft at the Tcase, but have yet to break a ujoint in my truck pulling or muddin. I can get them at bumper to bumper parts stores.
http://www.pirate4x4.com/tech/billav...ft/index4.html
You have probably been to this web page but it's a good write up any way.
ExPACamper
21
07-27-2017 06:48 PM
John & Old Ford
07-30-2012 04:11 PM
