Please HELP!
#47
The only "not bad" codes are
Being a 1987, you should be getting Code 11 if everything passes.
Additionally, there are three sets of codes that need to be pulled:
KOEO
CM
KOER
CM = Continuous Memory - where it remembers about the previous n operating cycles.
Fuel Injection Technical Library » How To Run a Self-Test
Yes, I know you don't have a check-engine light, some other light on the dash will flash in its place.
KOEO
CM
KOER
#48
I got the "11" code. All's well in KOEO mode. Having replaced one tank fuel pump and the main frame fuel pump and it driving fine for weeks after that and the fact I have usable fuel pressure I'm hard pressed to think it's fuel related. Although I'm not closed minded. At my age and my experience I've seen a lot of weird sheet. But, I'm betting it's electronic. Dang it. I need that pcm bench tested.
#52
brc777
06-09-2011 04:34 PM
BuckTruck
01-05-2011 04:18 PM
96onefifty
09-07-2008 04:37 PM
