1975 Ranchero Front end Springs removal?
Old 08-19-2012, 11:48 AM
chamblizi's Avatar
chamblizi
chamblizi is offline
Hey Phil, Here how do i remove the front springs in my ranchero... i am going to swap out my old springs with some springs that are a little bit more heightened. I am aiming to get a bit more tire clearance when i get my new 15 inch rims. I'm sitting on 235/60/15 but my front end sits low.. i should be able to at least slide under my truck instead of only being able to slide under the back.
Old 08-21-2012, 08:52 AM
parts4me's Avatar
parts4me
parts4me is offline
You know, most of your questions could be cleared up by getting and using a chilton's for your truck.
Old 10-02-2012, 06:26 PM
creativecars1's Avatar
creativecars1
creativecars1 is offline
Raise really high, put on jack stands!!!!<O</O
Pull wheels off, remove shocks, put safety chain around and through lower control arm, spring and frame so spring does not come flying out if something happens.<O</O
Place floor jack under lower control arm, almost touching, remove lower control arm inner nut, not the bolt yet, break lower ball joints loose, but leave nut on. <O</O
Raise jack to compress spring a little<O</O
Remove balljoint nut, wire spindle/brake assembly out of the way.<O</O
You may have to pull caliper so you don’t over stress the brake hose. <O</O
Drive out lower control arm bolt, being careful not to bump jack<O</O
Remove safety chain and slowly lower floor jack.<O</O
Good luck, be careful, coil springs can be dangerous.<O</O
Old 10-02-2012, 06:55 PM
chamblizi's Avatar
chamblizi
Originally Posted by creativecars1
Raise really high, put on jack stands!!!!<o</o
Pull wheels off, remove shocks, put safety chain around and through lower control arm, spring and frame so spring does not come flying out if something happens.<o</o
Place floor jack under lower control arm, almost touching, remove lower control arm inner nut, not the bolt yet, break lower ball joints loose, but leave nut on. <o</o
Raise jack to compress spring a little<o</o
Remove balljoint nut, wire spindle/brake assembly out of the way.<o</o
You may have to pull caliper so you don’t over stress the brake hose. <o</o
Drive out lower control arm bolt, being careful not to bump jack<o</o
Remove safety chain and slowly lower floor jack.<o</o
Good luck, be careful, coil springs can be dangerous.<o</o
THANK YOU THAT had red wing Ford Power Behind that.....
very professional.
MPD56
6.7L Power Stroke Diesel
1188
12-28-2023 09:04 AM
Lex2002
47
09-23-2013 09:53 AM
outsource77
08-24-2012 10:49 PM
TexasEX2K
07-05-2012 10:46 PM
DIYMechanic
15
06-20-2011 08:29 AM
Quick Reply: 1975 Ranchero Front end Springs removal?
