1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Pioneer AVIC-F90BT and XM Radio Tuner Installation in my 2012 F-250
Old 08-30-2012, 09:05 PM
madsonp's Avatar
madsonp
madsonp is offline
I recently installed a Pioneer AVIC-F90BT navigation system in place of the stock radio in my 2012 F-250 Super Duty. I also installed the Pioneer XM Radio Tuner that's needed to have XM radio on the AVIC-F90BT. But what I wanted to do is use the existing Ford factory Sirius satellite radio antenna and connect it up to the Pioneer XM radio tuner however where I mounted the tuner the factory antenna cable wouldn't reach. So here's how I addressed the issue and mounted the Pioneer XM radio tuner.
First of all I searched high and low for an extension cable to extend the factory antenna cable so it would reach the location I mounted the Pioneer XM tuner and just plug into each end, and here's what I was able to find.
The cable is 3' long which is just right for the way I mounted my XM tuner and plugs right in on both ends perfectly. Here's where it connects to the factory cable.
As far as the XM tuner installation location, I installed it in the glove box of the center console. To do this, remove the cup holders as shown here.
Cut a small hole between where the cup holders were and the glove box as shown here.
Feed the wiring through, connect it up, then use some good 3M double sided tape to mount the XM tuner on the side of the glove box as shown here.
Then feed the wiring on the inside lip of where the cup holders mount (There is enough room to do this without impacting the cup holders when reinstalled) then tape in place as shown here.
Then reinstall the cup holder and that's it. The best thing about this install is being able to use the factory satellite radio antenna with the Pioneer tuner so you don't have to try to figure how and where to mount the Pioneer antenna.
Old 08-30-2012, 09:22 PM
mtnsammy's Avatar
mtnsammy
mtnsammy is offline
Nice how about pics of the finished stereo?
Old 08-31-2012, 12:03 AM
madsonp's Avatar
madsonp
madsonp is offline
Oh, good point, here you go.
And in case you're wondering where I put the other antenna for the GPS, it's mounted on a structural steel piece just behind the stereo right under the dash. This antenna doesn't need to be mounted outside the vehicle, however needs to be mounted on a metal piece, with no metal between it and the outside of the vehicle (in this case there's only the plastic of the dash and the glass of the windshield. The antenna has full reception in this configuration, and there again there's no need to figure out how and where to mount it on the outside the vehicle.
Old 08-31-2012, 02:12 AM
djpahan's Avatar
djpahan
djpahan is offline
Love this model. Great choice. (have you mod'ed it yet?)
Old 08-31-2012, 05:44 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Very clean install.
Would the tuner have fit in the gap above where the stereo fits when bolted in? I have my lockpick up there but I wasn't sure, given the size of the tuner, if it would've fit or not.
Good choice on the brand, I love Pioneer head units.
Old 08-31-2012, 07:40 AM
madsonp's Avatar
madsonp
madsonp is offline
It is a great system, the only thing I've done to it was to do the bypass, so things can be operated without having to have the parking brake on. Do you have one? If so, what mod's have you done to yours? I'm also in the AVIC411 forum which is a wealth of information on all the Pioneer navigation systems.
Old 08-31-2012, 07:55 AM
madsonp's Avatar
madsonp
madsonp is offline
Originally Posted by 2000silverbullet
Very clean install.
I considered that, but it looked like it wouldn't fit, and there's no way to securely mount it in that location which is why I mounted it where I did. I agree with you on Pioneer units, Pioneer is all I'll ever buy, I never had any problems with any Pioneer system I've ever owned.
Redgranite_Yooper
04-29-2019 10:10 AM
PapaBearYuma
04-09-2018 10:35 PM
madsonp
05-20-2017 05:51 PM
PapaBearYuma
04-10-2017 01:19 PM
DaMole
09-25-2007 09:32 PM
Quick Reply: Pioneer AVIC-F90BT and XM Radio Tuner Installation in my 2012 F-250
