Arizona Chapter Join Chapter, Leader:
1994 E150 351, low voltage to fuel pump
Old 08-14-2012, 05:15 PM
perch57's Avatar
perch57
perch57 is offline
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->I have a 1994 E150 conversion van with a voltage problem to the fuel pump. I installed a new pump when the original pump suddenly stopped pumping. But then I discovered the voltage to the inertia swith is only 6.2 volts, after the new pump wouldn't run either. I checked the obvious but no solutions yet. Could the ignition swith be the culprit?
I need ideas. Thx
<!-- / message -->
<!-- controls -->
Old 08-15-2012, 11:07 AM
Bill W's Avatar
Bill W
Bill W is offline
wish i knew more about newer trucks or vans... newest one i own is 1966.
Bart, (Helifixer) might be able to help.
Old 08-15-2012, 07:47 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
We use to have a 1990 Ford E150 351 windsor never had a problem fuel pump wise but I will tell you that with other pickup trucks I have worked on I always checked the fuel pump relay they go out periodically. We had an 85 Pontiac 6000 same problem I asked my dad what are theses we replaced 4 of them car ran great. I would definatly replace them first they only are like 10 dollars a pop or so I think don't qoute me. I am not completely sure of where they are at on a van so maybe ask a mechanic.
Trav
Old 08-15-2012, 07:58 PM
Bill W's Avatar
Bill W
Bill W is offline
when my Dad worked at the copper mine all they had were ford trucks... he told me the mechanic's would carry a fuel pump relay around in there pocket because they went out so frequently.
Old 08-15-2012, 08:26 PM
Redneckfordf2502002
It is true Bill they go out alot and in those types of enviorments they are even more prone to problems. Anyways at around 10 dollars a pop it couldn't hurt it at all or your pocket to bad in some cases.
Trav
Old 08-15-2012, 10:07 PM
Bill W's Avatar
Bill W
Bill W is offline
my buddy's 96 was intermittent with fuel relay problems, he would be stranded by the side of the road for a hour or two and then it would fire up and run fine for a day or week. lol
Old 08-16-2012, 12:03 PM
perch57's Avatar
perch57
perch57 is offline
Thanks everybody, I'll try another one and see if it helps.
Old 08-16-2012, 12:42 PM
Redneckfordf2502002
Hope you figure it out. These older E150s with the 351 are great vans ours was just like it did everything we asked of it even got the life beat out of it till it went up in our house fire I still miss that old conversion van it did so great at hauling our family. Even with 167000 miles on the old son of a gun.
Trav
perch57
08-15-2012 02:44 PM
perch57
General Automotive Discussion
08-15-2012 12:17 PM
leardvr
02-18-2007 10:14 AM
zombie69
07-19-2006 06:02 AM
powercell24
12-12-2002 12:56 PM
Quick Reply: 1994 E150 351, low voltage to fuel pump
