rear end advice
I think Im leaning towards the 9" with 3.73's ls and keep an eye out for the front ls. Have to figure out how to identify the front ls. I can always turn a lot of wheels by hand and maybe get lucky. I wouldn't consider the welding option no offense. I like things as "right" as possible. thanks for the suggestion though.
Turning wheels to find a posi is VERY unlikely. First there are very few if any, and second if the one you happen to turn does have a posi chances are very good it will be too worn out to be able to tell my turning the wheel.
I've heard good and bad on the aod. I just flushed it and installed a diesel cooler but if it fails I'll probably go c-6. I've replaced timing belt. water pump all hoses and done the 3g upgrade. 2 new motorcraft fuel pumps. I would hate to start over but I do wish I had a 5'8 or diesel. truck runs perfect right now with not one drip anywhere but the rear end. I may get a better truck one day and keep this as a second but for now it's what I have.
Tire Gear Ratio Charts not sure if this is accurate or not
Gear ratio math;
Your AOD has an overdrive ratio of .67:1 which is pretty darn tall. Actually REALLY tall, before I had forgotten how tall it was. With an overdrive that tall 4.11 is no problem at all for highway cruise. Looking back the last rig like yours I did a gear change on I put 4.11s in it and it was mainly a mall cruiser.
Makes me wish I had an AOD over my C6 in my daily.
Looking at that chart multiply everything by .67 so 4.11 is really 2.75.
Well shoot by the math 4.56 sounds pretty darn atractive. Gives you a 10.9 total first gear ratio compared to your current 8.5 which will give you much better accelleration, off road, and towing ability. It gives you 28% more torque at the wheels for the same amount of engine work(throttle) making it feel like you have 28% more power. Takes strain off the transmission and engine, the rig will feel 28% lighter to the transmission and engine. And you still have a 3.05 final overdrive ratio for the highway putting you around 2500RPM on the engine at 65MPH
Total first gear ratio= first gear ratio x rear end ratio, so 2.4x3.55=8.5 compared to 2.4x4.56=10.9
Final overdrive ratio = overdrive ratio x rear end ratio, so .67x4.56=3.05 compared to .67x3.55=2.37 which you have now.
Torque at the wheel is muliplied by the ratios to. So comparing 3.55 to 4.56. 4.56 divided by 3.55 is 1.28 or 28% more.
#28
It was a 90 bronco with a 5.0, AOD and 31" tires. A C-clip in the stock 8.8 with 3.55 LS fell out. So I installed a 9" with 4.11s and a detroit softlock. She(the owner) had to put off doing the front gears, never used 4wd anyway and moved before I could change the front gears. At the time I just took the front driveline out to keep her from messing things up.
Putting 4.56 in your truck could be a little tricky from 2 aspects. Both the same, both I need to look up unless someone wants to chime in. The carrier which is the part the ring gear bolts to can work with a certain rang of gears before you need to change carriers, what that range is for the 9" and your TTB I need to look up.
Checking my math, a 31" tire travels about 730 rotations per mile. At 65 MPH thats 47450 rotations per hour, 791 tire rotaions per minute. Muliply by the final gear ratio (ie 3.05) gives you about 2400 engine RPM at 65MPH.
The 2500RPM number in the previous post was from the chart.
#29
a full exhaust with good headers will help and so will this:
ignition upgrade and timing bump (no 56K) - FSB Forums
OK so no carrier split with the 9" so any carrier you can just bolt on 4.56 gears. Pretty sure your TTB is Dana 44 based so it's split would be 3.73 so any gear numarically higher then 3.73 and you need a different carrier.
maddog14
05-13-2015 03:33 PM
offroad_guru
09-03-2004 12:47 AM
jroehl
05-01-2004 01:33 PM
