2003 F150 5.4V8 Triton 4X4
Old 08-11-2012, 09:06 PM
Paul Kruse's Avatar
Paul Kruse
Paul Kruse is offline
Question 2003 F150 5.4V8 Triton 4X4
I have a 2003 Ford F150 with a 5.4V8 Triton 4X4. The truck is about to roll over 200K here soon. I am feeling/hearing a vibration/grinding sound coming from the truck when I am moving slowly and making turns, either left or right turns. Seems to happen more so on left hand turns. I have changed all power train fluids and filter, and still does it. I do not feel or notice the vibration/grinding when I am going straight or at highway speeds. It is only when I am moving from a stop and making turns. Any suggestion on how to diagnose, find out, repair, fix this issue?
Old 08-11-2012, 09:30 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
did you add the friction modifier to the rear axle ?
https://www.ford-trucks.com/forums/1...f-rebuilt.html
Old 08-11-2012, 09:32 PM
Paul Kruse's Avatar
Paul Kruse
No I did not. Is that something that should have been done?
Old 08-11-2012, 11:23 PM
Torky2's Avatar
Torky2
Torky2 is offline
Yes if you have a limited-slip axle. Check your door jamb for axle code and look it up. It used to be that if the axle code was a "9" for example, that was a 3.55 axle ratio, open differential. A "H9" was 3.55 ratio with limited slip differential. Your codes are probably different, but you could search or post your code here and someone can tell you whether it is open or limited-slip. The differential on a limited-slip axle has a clutch pack between the side gears. The special additive gives the proper slip-stick shearing effect. Without the additive, it acts grabby when cornering.
Old 08-12-2012, 09:04 AM
steve(ill)'s Avatar
steve(ill)
jerky motion when turning, but no problem when going straight line is 100% = lack of friction modifier with an LS unit.
TheBlueMule
04-04-2014 10:34 AM
kjjr20
2009 - 2014 F150
10-21-2012 04:05 PM
F250TRKS1
09-11-2006 06:11 AM
flyinghorse
1997 - 2003 F150
12-18-2003 02:21 PM
Maitland
02-15-2003 01:47 PM
Quick Reply: 2003 F150 5.4V8 Triton 4X4
