Vin Decoding information
Good evening I just joined this evening,
I was given a 1987 F-250 that my father-in-law purchased brand new. The vehicle currently has over 300,000 on it so I'm going to start working on it very soon. I'm trying to decode the vin number, but I'm running into a problem. The model, cab, chasis type of my vin does not match with anything I can find. My vin indicates F34, unfortunately I can"t find that code anywhere. I hope that soemone out there can help. Thank you
Received 3,107 Likes
on
Thanks guys, the only reason that I'm trying to decode is for curiosity. When I tried to decode it I was able to decode everything except for the body style. So I'm curious why this body style F34 is not coming up, I was unable to find in in the shop manual either. Thanks again!
This is the vin# 1FTF F34 N4HPB36742
on
everything you need in on this page:
VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Your VIN number: 1FTFF34N4HPB36742
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Truck (Completed Vehicle)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class F, GVWR 7,001-8,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series Super Duty - F350
Chassis Type: 4x2
Body Type: Chassis Cab - Regular Cab
Engine Type - 8th Position:
Engine: 5.0(302cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: 185
Model Year - 10th Position:
Model Year: 1987
Assembly Plant - 11th Position:
Assembly Plant: Twin Cities: St. Paul, Minnesota
Production Sequence Number - 12th - 17th:
Sequence Number: B36742
Make: Ford
Chassis Type: 4x2
Engine: 5.0(302cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: 185
Model Year: 1987
on
norman2012
16
01-01-2017 07:34 AM
Smokin'
12-11-2009 12:44 PM
