1978 - 1996 Big Bronco
My new college rig.
Old 11-04-2012, 01:22 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
I don't mind mind too much, I wish it sounded better and was built better. the flex pipe really is junk.
  #62
Old 11-04-2012, 05:10 PM
justforkicks's Avatar
justforkicks
justforkicks is offline
Yeah i may just cut the pipes right before the y and run em back. Wont even bother with that o2 sensor.
  #63
Old 11-04-2012, 05:13 PM
justforkicks
Does that flex pipe leak or what?
  #64
Old 11-04-2012, 05:23 PM
GruesomeJeans
The flex pipe was put on very badly using big hose clamps. They do leak a lot and my manifolds leak. Then it has the cherry bomb tube on each side which some people say it sounds ok but i still think it sounds pretty bad.
  #65
Old 11-04-2012, 08:39 PM
89fordhalfton's Avatar
89fordhalfton
89fordhalfton is offline
i know this has been on awhile and a little off subject but i had a 95 f150 and true dualed it with 2 and a quarter inch steel gate pipe( i know it is small but it had a sweet *** cackle to it along with it being loud and i had plenty of it free .. just like my 90 did) i just cut in front of the cats and went around the cross member and up and over the back axle then come out the side but like i said it sounded RIGHTOUS
  #66
Old 11-04-2012, 09:18 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
2" 1/4 is about right for duals in a Bronco, but a single 3" pipe is the preferred setup. The performance effects should be the same.
  #67
Old 11-05-2012, 11:55 PM
justforkicks
Hmmm... well does anyone know of a good, free flowing dual in dual out muffler? I heard the magnaflows burn out quick. Preferrably chambered.
  #68
Old 11-06-2012, 12:59 AM
GruesomeJeans
Flow master then? Maybe the super 40's? I know the regular 40's have had a history of drone noise in the cabin but i am sure they make them in dual in/out setups. And las i checked they were chambered.
  #69
Old 11-06-2012, 02:00 PM
NewEnglander's Avatar
NewEnglander
NewEnglander is offline
Ive got the super 40's in mine but its only a single in and single out, with 1 cat removed and vented it before the wheels and I love it. It may not be as loud with the full tail pipe but it may be a bit deeper than how mine is.
These are both I took. The offroading one is good one to listen to it from inside with windows up
  #70
Old 11-06-2012, 02:52 PM
GruesomeJeans
I wouldn't mind using super 40's but i would probably go with the imitation flowmasters cause they are cheaper to purchase.
  #71
Old 11-07-2012, 08:27 AM
smokenchoken's Avatar
smokenchoken
smokenchoken is offline
i would just get a set of side pipes and not worry about anything being in the way plus they sound awesome
  #72
Old 11-07-2012, 03:52 PM
GruesomeJeans
Only issue with that is with a 96 you have emissions stuff to deal with. I don't know if having side pipes is going affect that.
  #73
Old 11-07-2012, 09:22 PM
smokenchoken
not that i am aware of..... all your emission stuff is before you channel it back forward
  #74
Old 11-07-2012, 11:31 PM
Encho's Avatar
Encho
Encho is offline
The O2 sensors might be the only issue to be addressed.
  #75
Old 11-08-2012, 09:47 AM
Boss351Bronco88's Avatar
Boss351Bronco88
Boss351Bronco88 is offline
I had a 1 in-2 out Flowmaster(50 or 80 series) I believe it is called a "crossflow". On my 88 351w. 2.5 in...used to be on my 91 Aerostar 3.0L lol. It sounded pretty good, except that it droned horribly. I had it dumped before the axle. Now that I have the motor built. Im running Hedman Elite thermal coated full-length headers, with a custom y-pipe, Full stainless 3in pipe, Flowmaster 40 series muffler, exiting from the stock location. It sounds great. Just like New Englanders...except more powerful/cammed. lol. I have an electric cutout for it as well that needs to be installed...But I have to pull the motor again due to a lower end knock.
You got yourself a good deal...and keep up the good work. I paid only a grand for mine...ended up only having 49k original miles on it. But it was a mess and Ive put alot of time and money into it...and Im still far from finished lol.
Quick Reply: My new college rig.
