instrument panel
instrument panel
i dont have a tach in my truck yet... but i read somewhere on this site that if you push some buttons or run a jumper that you can ring up a digital tach in the area of the odometer OH and something else i just found... my truck has 2.73's.. it sucks. the truck is as slow as f***.. well if someone knows how to do it let me know.. thanks
instrument panel
You have to change the whole instrument cluster to get a factory tach, but it's easy and you can swap your original speedometer into the new cluster so you keep your mileage. Check the classifieds and eBay for replacement clusters.
If you want an aftermarket tach, you can use the factory wires at the instrument cluster connector.
instrument panel
I think you got a couple procedure mixed up. You use the jumper and the buttons to change the calibration of the odometer. (if you change tire sizes)
To ad an OEM tach, check out my article in the tech section:
OEM Tach How-to
OEM Tach How-to
I have a 2005 F-150 FX4. You can hold down the button for the IP and then start the truck. It will then say "sweep guages". You can now press the button and scroll through the menu until you get to "tach". It will then display tach in real time. There are other things like DTC's, Battery volts, CAN messages, etc...
Hope this helps...
Hope this helps...
Aune163rd
12-13-2014 08:02 AM
rowdyredneck
08-03-2013 10:45 AM
03trueblue
08-26-2012 09:30 AM
Kenneykole
13
05-07-2012 04:37 AM
