1978 - 1996 Big Bronco
92 Door Removal
Old 08-06-2012, 12:36 PM
v8xploder's Avatar
v8xploder
v8xploder is offline
92 Door Removal
Going to pull my doors as im almost done stripping the body for paint on my 1992. Im painting the doors and tailgate separate, This will make doing my door jambs easier and help with space in the garage issues. Lookin at the hinges I think if i remove the bolts that hold the hinges to the door and leave the hinges in place will be my best bet. Does each side (hinge to body and Hinge to door) have adjustments on both or is just one side adjustable? So far ive placed masking tape around the door where the hinges bolt up and traced with a marker to help align backup ( didnt want to scribe marks in the door) I have not pulled the doors yet, i figure id ask first. Thanks
Old 08-06-2012, 08:13 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
The adjustment is on the jamb side of the hinge. The door side should be fixed.
Old 08-08-2012, 04:51 PM
v8xploder's Avatar
v8xploder
Got the passenger side off now the driver side is being a bit more stubborn...
I pulled the park brake assembly out of the way so that I could disconnect the harnesses on the driver side I can get to the one grey harness but the others I cant reach they seem to be up behind the dash somewhere...
I thought maybe ill jsut disconnect all the electrical from the door and pass it thru the hole (where the rubber hose goes between the door and jamb but the power window switch wont fit thru the hole. Am i missing something??
Old 08-08-2012, 06:15 PM
greystreak92
The harness should disconnect from the switch assemblies and you should be able to pass the connectors through the holes one at a time. That's the inverse of the assembly process.
Clem's Cousin
06-09-2016 09:58 PM
98Econoline150
06-01-2015 10:09 PM
twinpeaks
02-07-2010 07:55 PM
Greg 79 f150
Paint & Bodywork
01-02-2004 02:52 PM
stRanger706
1983 - 2012 Ranger & B-Series
12-24-2003 07:59 PM
Quick Reply: 92 Door Removal
