1986 f-150 Stepside Fuel Filler Hose Assembly
Old 08-04-2012, 11:07 AM
JAP's Avatar
JAP
JAP is offline
Help! I am screwed by the CA DMV! My '86 F-150 Stepside won't pass smog. It fails the evac by.006 and needs a new fuel filler hose which is no longer available. I need part # E4TZ9034B. Can anyone out here help me? I don't want this great old ranch truck to be crushed but the once great state of ca does. Save the beast
Old 08-04-2012, 11:38 AM
Labhound's Avatar
Labhound
Labhound is offline
In before the step side vs. flare side... I just looked in the NPD catalog and didn't see any, try e bay.
Old 08-04-2012, 02:49 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Seems to be a filler pipe for the midship tank, fits 1984/85/86 with 4.9, 5.0, 5.8, gas engines or 6.9L diesel. IOW any engine.
Looks like junkyard or aftermarket, these have been sold out for at least 4.5 years now.
Old 08-04-2012, 03:10 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Dual tank trucks are exempt from that evac test.
The evac test has been known to make parts in the evaporative system fail on occation as they pressurize the system and crimp off hoses that are 30+ years old. They will argue that it was about to fail anyway etc...
Good thing though is the midship tank filler hose is the same 1984-1986 as CTUBUTIS describes, and for trucks with or without dual tanks. So you have some options on finding one in the wreckers.
Old 08-15-2012, 02:01 PM
semi 104's Avatar
semi 104
semi 104 is offline
fuel filler hose
HI: I am new to this but I have an 84 step-side that I am putting a tank behind the rear axle & I still have that filler hose.
Again I can not read the numbers on it but is about 28 inches long with a black about 3/4 in hose down the center.
If you thing that is what you need then just pay the postage & I will wrap it & send it to you, again I am not sure it is what you want.
Jim
Old 08-15-2012, 05:38 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,720 Likes on 1,391 Posts
I would get creative and make one out of exhaust pipe and rubber fuel hose. I would imagine the proper hose would be expensive and hard to find, but I would try Napa first. You only need short pieces with clamps to put the exhaust pipe together.
Old 08-15-2012, 08:05 PM
81-F-150-Explorer
It would still need to hold pressure during the smog test.
I agree with Franklin2.
If the smog shop can't tell it's different, and it works as it's supposed to, then that should work fine.
Never did understand the banality of California Smog laws and swapping parts. It has to be exactly like original, or have an EO number, etc... All they should care about is clean air, not red tape.
Old 08-15-2012, 08:38 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Given that these trucks are older than some of the "smog techs" I've seen, how would they know what the original part looked like?
Old 08-15-2012, 10:58 PM
JB-1's Avatar
JB-1
JB-1 is offline
Old 04-21-2019, 07:43 PM
JJKennamer's Avatar
JJKennamer
JJKennamer is offline
Jim
I know it has been years, but do you still have this hose?
Thank you.
j j k e n n a m e r @ g m a i l . c o m
Old 04-21-2019, 08:41 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Considering how old this post is I doubt he would still have it.
I haven't been that desperate myself but below is a site that sells the parts to cobble together a replacement filler hose for the 80-86 flareside trucks.
https://www.fillernecksupply.com/198...se-front-tank/
Old 04-21-2019, 10:28 PM
Big-Dawg's Avatar
Big-Dawg
Big-Dawg is offline
Check Rockauto.com
Hope this helps. Good luck!
Old 04-22-2019, 03:04 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Big-Dawg
E1TZ-9047-C & E1TZ-9047-D are for Regular & Super Cab STYLESIDE pickups.
The OP has a FLARESIDE pickup, so these hoses will not work!
Old 04-22-2019, 04:27 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,160 Likes on 1,833 Posts
Thank you.
I don't know if you will be back but what parts do you have to make this rear tank work in the flare side?
Note the fuel door on the flare side is different than the style side trucks.
I have installed a rear tank in my flare and used a combo of Ford truck parts.
Parts I had to pick from.
Someone butchered my flare front tank fill. They cut the metal neck short and had some sort of longer rubber hose.
Had a flare side front fill from door on down to the tank. This also had part of the fender I grafted to the rear of my flare side fender.
Style side front tank from door to tank and the tank too.
Style side rear tank from door to tank and the tank too.
I don't remember just what parts were used where but I started with the front tank and took what fit the best. I think it was the style side front parts?
On the rear I grafted the door to the fender so I knew where it would be to connect A & B to fill C LOL
The neck was a short straight part. I had a straight rubber hose on the tank and it came out past the frame rail.
I also had a 90* rubber hose. This goes from the tank hose, using exh pipe to join the 2, and the short straight neck bolted to the fender.
The inner plastic hose I had to use 2 to make 1 and I used copper pipe & hose clamps to join the 2 together.
Front filler
Rear fill
Dave ----
w4gy
WTB - Parts & other
03-12-2013 09:56 AM
shotgun2
11-15-2011 11:38 AM
ghunt
WTB - Parts & other
05-13-2010 03:07 PM
Swampdonkey09
12-03-2003 08:09 PM
tuffguy
06-17-2002 02:40 PM
Quick Reply: 1986 f-150 Stepside Fuel Filler Hose Assembly
