Wheel swap question for the darksiders
Since the last time I posted the wiring is done although I haven't powered up yet . My next task is to swap out the MOPAR WHEELS . Has anyone tried a 4.5 FORD WHEEL on the MOPAR front conversion and if so do they fit ? I have a guy that is interested in trading my set ( Chrysler 5th Ave wheels) for a set of FORD CAR wheels . I would really like to go with the FORD style so that I can run the FORD hubcaps and trim rings . My rear axles are already downsized to the 4.5 bolt pattern . I tried an aluminum wheel from a Explorer but it didn't fit over the front hub . Any thoughts ?
go to Tire Rack.com they have good wheel interchange info. If the center hub hole is too small in the steel Ford wheels (by not too much?) you could gring them out. The Ford steel wheels are stud centering, not center hub, so the hub hole doesn't have to be perfect like on aluminum wheels.
hold it in place, the hub hole is just for clearance. In 4x4 use, there is a lot of stress on the lugs due to rocking back and forth and slipping and grabbing so the hub holes help to keep from wallowing out the stud holes in the wheels, especially should the nuts not be tightened sufficiently.
Sam
M3talGuy
38
06-24-2021 10:41 PM
zukinut
01-27-2013 09:33 PM
QwkTrip
1999 to 2016 Super Duty
08-08-2009 12:35 PM
EZLariat
2004 - 2008 F150
07-16-2004 08:09 PM
