I have a 2001 Superduty 5.4 with an Automatic. Will a 7.3 trans with PWM lockup converter work properly , if plugged into my PCM? I'm not sure if a 2001 5.4 4r100 has PWM or NON-PWM lockup. Thanks
A gas PCM can control a diesel transmission, as long as it is also controlling a gas engine. Without an engine to control the PCM will not control the transmission.
