Gunk in coolant
Old 07-29-2012, 08:07 PM
Macmathews's Avatar
Macmathews
Macmathews is offline
Gunk in coolant
Went to change my reservoir tank cap and noticed the rubber oring was melted and see some light brown gunk floating around on top?
Just by chance I was reading this could be cracked cups?
How do I tell this and or rule this out?
What are my next steps ?. Advice please
7.3 150'000 miles
Kyle
Old 07-29-2012, 08:16 PM
F350-6's Avatar
F350-6
F350-6 is offline
If it's cracked injector cups, you'll have diesel fuel floating on top of the coolant. Stick your nose down there and see if it smells like diesel fuel.
It could just be time to flush your coolant.
Old 07-29-2012, 09:01 PM
Macmathews's Avatar
Macmathews
I tried the smell test and could not tell
I'll have to get my wife sniffer involved since hers is way better.
I was mainly concerned about the mushy rubber oring in the reservoir cap
Thought maybe this was a tell tale
Thanks for your help
Kyle
Old 12-23-2014, 02:18 PM
Macmathews's Avatar
Macmathews
To relive this thread.. shortly after this I had ALL my injector cups replaced..
Not on mileage but its been just over 2 years and BAM . fuel in the coolant again.
I was thinking this time I would only get the faulty cup changed..
What are your thoughts on this ??
Seems to me like a good idea since 7 cups are likely still good.. Why do all 8 when a single 1 could fail again at any time ?
Kyle
Old 12-23-2014, 02:22 PM
jgilrfr's Avatar
jgilrfr
jgilrfr is offline
I dont think there is anything wrong with changing one cup,people go thousands and thousands of miles without changing all of them
Old 12-23-2014, 02:23 PM
jgilrfr's Avatar
jgilrfr
jgilrfr is offline
make sure you change all of the o rings and the copper washers
Old 12-23-2014, 02:25 PM
Macmathews's Avatar
Macmathews
Since my truck is an excursion .. It would be nice if the issue was in the drivers side bank..
Since there's a nasty heat box to remove on the passenger side.
Any other tips ideas.
Kyle
Old 12-23-2014, 03:19 PM
montanasteve's Avatar
montanasteve
montanasteve is offline
Check your injector hold down bolt torque before you pull the injectors. Tugly had mentioned that he saw in the Ford service manuals that an injector hold down bolt that has loosened to below 50in-lbs should be pulled to have the cup checked for cracking. That could possibly help narrow down the offending cup, and give a reason as to why it failed.
Old 12-23-2014, 04:35 PM
Tugly's Avatar
Tugly
Tugly is offline
I don't recall the heat box on the Ex being any different than on the P/U, but I certainly remember that fender well not letting me at the VC bolts from the side.
13mm flex socket took care of the VC bolts down low, and 1/4" universal joint took care of access to the #5 injector bolt. Other than that, foul language helps when the heater stays in place. Ex owners - please correct me if needed.
Yes... check the injector torque - that's what likely killed my cups in the first place.
Replace only the cup found to be bad - good luck isolating that without removing all your injectors. I drained all coolant from the engine, exposed the cups, sprayed them with silicone spray, then pressurized the coolant system to 15 PSI:
I can't stress this enough: Loose injector or poor cup prep will have you in there again. The cup needs a factory-new clean surface to adhere to for a reliable seal.
Old 01-28-2015, 12:58 PM
Macmathews's Avatar
Macmathews
Update..
Was not diesel in coolant..
Was a line of Gunk but my mechanic did find an issue with injector number 8.
Did test of coolant and was less than 3% diesel.
Just thought I would update for reference in the community
Kyle
Deluxe06
16
03-04-2014 02:26 PM
RLICHT
23
12-08-2013 08:22 PM
73watermutt
17
05-15-2013 10:52 AM
zeppelingto
12-13-2012 11:33 AM
jim fowler
09-17-2009 10:39 PM
Quick Reply: Gunk in coolant
