Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Oil Change How To
Step by step instructions for do-it-yourself repairs
Best 7.3L Oil Filter & Best Price
+1 on this most auto parts stores usually carry the FL1995 for around 10.00 if Wallyworld is out. They seem to have good prices on oil too, I just bought 15qts and the filter for just under 68.00
The following users liked this post:
I have a huge drain pan that is probably 8" deep and 18" across that barely holds all the oil if you start with it empty. After I fill the motor with oil I use the empty oil bottles. I usually fill 10 or so before I take them all to the dump and pour them out for twenty minutes. I don't know anything about those two oils. My Ex has only ever had Shell Rotella T 15W40 in it. About 15,000 miles ago I switched to Rotella T6 Synthetic. In my experience Shell oils are excellent. My oil analyses from blackstone labs show great results.
I also run RotellaT 15-40 also bought at Walmart. One of the main reasions is just about every truck stop carries rotella. I personally don't like to mix oil brands, and it's usually 13.00 for 4 quarts. Walmart also sells individual quarts of rotella as well. I use a standard 18qt drain pan then use the jugs to transport it
Also, what do you guys use to catch/store your old oil until you
can take it away or have it picked up?
Stewart
I had been using the Motorcraft 1995 from walmart, but I am going to switch to the Mobil 1 M1-601. It is an extended range filter with synthetic media. I am using Shell Rotella T6 Full Synthetic oil and changing it at 7500-8000 mile intervals. If you are gonna change your oil every 3k, I think the Motorcraft is fine, but for longer intervals, I would suggest an extended performance filter with synthetic media. The Mobil 1 is only $2 more.
I used Rotella 15-40 all the time on my cummins, after I added my f450 to the fleet, and I realized I now needed 7 gallons every time I changed both of them, I was always chasing the lowest oil price, I bought 8 cases of Valvoline Blue, and that lasted me for a while.
I have not found a good enough deal on oil that it is worth it for me to change my own oil on my diesels, My local diesel shop will change it for $65 bucks. By the time I buy the oil and filter it is more then that. Now that I have added a 3rd diesel to the family, he will be getting all of my oil change business. They use rotella15-40 and ford motocraft filters, so it is worth it to me to let someone else play in the oil, though I have spoiled them, since I have Fumoto drains on all but the one I just picked up this past weekend.
I have 3 TDI's and the 7.3 I buy 2 19L (5 Gallon) pails of Rotella T6 5-40 when Canadian tire puts them on sale for $127 (i think ) I use Ford Filters from the dealer (have not seen them any where else) and Boche for the TDI
Change them twice a year or 10,000km (6200 Miles) what ever comes first
They seem to have the sale every 3 months so it works out for me
