Air conditioning 2003 Ranger
A few weeks ago I came out to my 2003 Ranger 4 Cyl. only to find the battery dead. I mean 100% drained. The morning before after my trip to work I noticed the AC lines under the hood were iced up and did not connect the two. I eliminated all other circuits that might be draining the battery so I decided to see if the icing and the battery were connected. I unplugged the A/C compressor and bingo. No more battery drain while the truck was parked. Once I re-connected the A/C compressor plug the system iced up after about 30 miles of driving. I parked the truck and the battery drained again. I am thinking the A/C clutch switch is the issue. The compressor does not cycle on and off but runs continously with the pug connected. Disconnected the clutch is off and the compressor does not run. I have been running the air while driving and disconnecting the battery when I have to park it overnight. The constant compressor operation can't be good.
Anyone been here before and can someone guide me to what and where is the fix?
Thanks
Tony
Thanks
Tony
Thanks
Tony
Thanks
Tony
Look to a faulty AC line pressure switch, or maybe a short in the pressure switch wiring.
NapaValley
11-28-2018 10:34 AM
nuthinbutfords
Modular V10 (6.8l)
07-21-2010 09:13 PM
257robertsimp
1983 - 2012 Ranger & B-Series
07-06-2007 07:52 AM
