E-350 starting problems
07-20-2012, 08:19 PM
on
My mom has a 2005 E-350 5.4 auto that sometimes doesn't start when it's in park, however if she puts it in neutral it does, any input?
07-20-2012, 09:52 PM
Neutral safety switch needs adjustment.
07-20-2012, 09:58 PM
on
Do you know where that is on a 4r100? I searched alldata and couldn't find it
07-21-2012, 06:18 AM
I think it's on the side right where the shift cable hooks up
07-21-2012, 12:36 PM
On newer vans like yours its called the MLPS. Manual Lever Position Switch. Its also sometimes called the DTR (Digital Transmission Range) and TRS (Transmission Range Sensor). Autozone lists it as a Transmission Range Sensor, and it's 66 bucks there.
07-21-2012, 03:28 PM
on
Is it something that can be adjusted? or is it better to just replace it?
07-21-2012, 05:30 PM
I'd try adjusting it first. If that doesn't work, replace it. As it has resistors in it, and the one for park could be burnt out.
07-21-2012, 07:12 PM
on
Quote:
Originally Posted by
hav24wheel
It doesnt do it every time tho
markcarver
2004 - 2008 F150
09-01-2018 10:09 AM
fordvanguy88
07-25-2017 07:24 PM
bthr22
1999 to 2016 Super Duty
22
08-25-2013 05:23 PM
prisoner of gravity
09-26-2010 05:24 PM
69ford99
1978 - 1996 Big Bronco
10-01-2006 10:51 AM
