drive shaft coupler
Old 07-18-2012, 08:03 PM
rangerskip's Avatar
rangerskip
rangerskip is offline
6th Gear
drive shaft coupler
I have an 88 2.3, 5 speed, 2wd extended cab ranger. Recently the composit rubber drive shaft coupler started to fail. Anyone know / have a replacement unit? I have been on line & through all the major junk yards in my area.
Anyone been through through a drive shaft modification / rebuild to get around this problem?
ANy help is appreciated.
Old 07-18-2012, 08:42 PM
michigan66's Avatar
michigan66
michigan66 is offline
Have you checked with a Ford dealer to get the part number at least? If the folks in the parts dept. are of the helpful variety, they may tell you where you can get a replacement part.
Old 07-18-2012, 08:55 PM
rangerskip's Avatar
rangerskip
6th Gear
I tried 2 different dealers & got the same story "..production stopped in 1999 & they can't get a replacement". I have been to ~ a dozen junk yards here in central PA with no luck.
Thanks.
Old 07-19-2012, 10:20 AM
Rangerman Stan's Avatar
Rangerman Stan
Rangerman Stan is offline
You'll need to go to a driveline repair shop where they can replace or build drive shaft components. There should be a shop in your area or closer to one of the larger cities around you. Check your phone book or on your Iphone. Some of the auto service shops in your area may know of one that is good. Ask around at the parts stores too.
Old 07-21-2012, 08:59 AM
slc10844's Avatar
slc10844
slc10844 is offline
I have not been able to locate one for your Ranger, but after much searching on the web have found that the coupling is very common with foreign cars, especially Land Rover and BMW. They are referred to as Guibo or Rotoflex couplings. Even Corvette uses them on axle shafts. The coupler is designed to reduce vibration but can cause vibration if they begin to fail. An alternative is to replace the coupler with u-joints as Rangerman Stan has suggested.
praft81090
09-19-2017 07:33 PM
99F-350CrewCab
Illinois Chapter
01-29-2010 06:19 PM
e william
15
04-24-2008 05:46 PM
dman255
1999 to 2016 Super Duty
04-04-2008 03:45 PM
busakiller2001
11-09-2007 12:43 PM
Quick Reply: drive shaft coupler
