09 F150 intergrated brake control
Old 07-18-2012, 03:28 PM
duckhunter 51's Avatar
duckhunter 51
duckhunter 51 is offline
Any ideas? My dealer said $350 plus looked at ebay 09-10 for $199 but the model # does not match up. Their is another on ebay with correct # for $263. $199 sounds alot better. Any ideas
Old 07-18-2012, 08:23 PM
Greg B's Avatar
Greg B
Greg B is offline
I would highly recommend that you stay with the correct model number and part number for your truck. You'll most likely have fewer problems. $263 doesn't sound bad for the correct integrated brake controller. If money is a big issue I recommend a quality aftermarket brake controller like the Prodigy P3. It's almost as good as the factory unit for around $180 with the ready-made harness to plug into the factory trailer tow plug. It's truly plug and play. But you'll lose the anti-lock brake function of the factory controller. Just remember that sometimes spending a little more $ up front is less expensive in the long run. It's always cheaper to do it right the first time.
Old 07-19-2012, 10:42 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
i have a Prodigy in my F350 and i love that thing! Simply push button for boost settings and a simply dial that increases the voltage to the trailer, six years with it and never a problem
Old 07-19-2012, 08:03 PM
Greg B's Avatar
Greg B
Greg B is offline
I love the Prodigy in my 06 F150 also. I had the integrate brake controller in my 05 SD and loved it. Prodigy is very close to the factory set up. You just don't have ABS on the trailer with the Prodigy. I bought the ready-made harness ($15) to plug into my factory trailer tow harness and had the controller installed and operating in 10 minutes. It actually took longer to decide where to mount it than the install took.
Old 07-19-2012, 08:42 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Why would you clutter up your dash with an old school brake controller when you can have the factory controls and state-of-the-art in technology with ABS and sway control?
I had a Prodigy in my Superduty. Worked fine. Wouldn't go back for a moment now that better stuff is available.
Old 07-20-2012, 08:35 PM
Greg B's Avatar
Greg B
Greg B is offline
Because the factory integrated brake controller wasn't available on an 06 F150 and I was told that the PCM on an 06 F150 would not support one. So Prodigy was the next best thing.
Old 07-20-2012, 10:14 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
This isn't about you. This is about the OP who has a newer truck.
guthrie&co
01-21-2010 08:25 AM
wi_bigfoot
2009 - 2014 F150
07-19-2009 11:02 PM
xd2200
1999 to 2016 Super Duty
06-03-2009 03:38 PM
janstang351
2004 - 2008 F150
03-09-2004 08:59 PM
62BigBlue
03-25-2003 04:07 PM
Quick Reply: 09 F150 intergrated brake control
