H.I.D no high beam
H.I.D no high beam
I have a1995 f150. I put 8000K hids in about a year ago. The kit was basically plug and play, it used one of the plugs from the stock headlight, then needed to be connected to the battery, and grounded twice. The only problem I have experienced is my high beams don't work, haven't since I installed them. Does anyone know how to fix that?? (No high beams or flash-to-pass)
on
By definition a discharge lamp such as those found in a HID headlamp only have 1 element so to speak.. they don't actually have any elements because they work more like a flourescent lamp than a halogen lamp, but what that means for automotive applications is there is only one beam and it will be either high or low depending where the headlight assembly is physically aimed.
