Sounds like tire roar but it ain't, wtf is it?
My practially new 1996 Explorer, 4wd, 4.0 with only 162,000 miles has developed what sounds like tires with agressive tread roar. The tires are Goodyear Wrangler RT/S with maybe 20,000 miles on them. I have had tie rods, upper and lower, shocks.The CV boots are like new. Front end was aligned when front end work was done. Tire wear pattern is normal. Tires rotated last week (I hoped that would stop the roar, no affect). Transfer case and front diff. show no signs of lube leak. I am at the end of my wits as to what can cause the roar. At 30 MPH I have to turn up the volume on the radio to hear, at 60 the roar fades.
A slight turn to the right on the steering wheel and the noise stops.
Any suggestions will be greatfully appreciated!!!
wheel bearing.
sometimes they don't goof up your treadwear, but when you said it goes away when turning one direction ...... telltale sound a bad wheel bearing assembly makes.
to figgure out which one, put the back up on stands-wheels off the ground. then put it in 4wd and lift one wheel in the front and idle in gear.
you will be able to easily tell which one by doing this.
just BE CAREFUL!!!
just BE CAREFUL!!!
Escape & Escape Hybrid
08-20-2017 07:38 PM
tseekins
02-19-2010 05:43 AM
rpm5099
12-23-2008 01:22 PM
