View Poll Results: Best Bang
Voters: 15. You may not vote on this poll
What is the best bang for my buck?
Going to have about $1,500 to $2k to spend on truck come October. I'm looking for better performance/reliability.
1. 4.56 gearing and a trac-lock/Detroit in rear axle, traction bars. Maybe a trac-lock in front if $$$ exists
or
2. PCM rollback, FICM rebuild with Atlas 40, ARP's (1 at time method), SRL+/Looney Wild tune
Gearing will essentially eat my budget completely.
Option 2 will leave me about $500 to play with...but I already have a serious case of 1 tire fire since factory LS is gone
Opinions? Doing a poll to try and collate it
or
Sorry, I can do Option 1 in entirety...or option 2. I want to pick one route or other and see it to completion, then next go around fulfill the other option
I'm a Mechanic by trade, and have all the cool gadgets that I could do the gears install myself. Just can't justify paying over $1k labor. Especially as that'd free up $$$ for me to get front and rear trac-locks
Edit: gears and traction adder are needed because right now I can light up my right rear tire at will with 3.73 gears. Figure if I'm in there for a Detroit or Trac-lock that I'm not going to waste the opportunity to upgrade gears at same time. Besides, getting back 1-2 MPG wouldn't be so bad either since I drive 90% city
I'd do the gears/lockers minus the ladder bars, and spend that money on the FICM tuning/rollback. I don't see the reason for the bars, if you're having an axle wrap issue ditch the blocks and add in leaves, 4.5" isn't that much lift.
I know you said you don't want to mix and match, but I didn't pick the tuning/studs option only because I wouldn't do a one-at-a-time job on the studs. I'd want new gaskets in there, plus a chance to at least check the heads. If you were in Texas I'd wonder why you're choosing to do it that way, but you being on the island/time constraints of deployment might make it worth the risks of doing it a second time later.
@ MD - I can hope they go together. Truck already has plenty of *****. I just want it to have some more. Dunno why
I'm doing one at time studs because truck has 13,8xx miles with no indications of lifting. And I'm deployed 200+ days a year. I'm taking 10 days of vacation in August and that'll be first time I've had off since Dec. Not too much time for motor tears downs when you work 100+ hours a week. Wife gets jealous of my spare time
Need some ladder bars for the axle wrap. Unless I can score some cheap Icon/Deaver lift leafs, the blocks are going to stay to keep a decent ride. Looking at maybe forking over $$$ for OUO Bars that replace current blocks.
Because some power is never enough!! I've debated the 5 Star Tuner for my truck but even with great reviews and what seems like zero problems just can't seem to pull that trigger.
