Sputtering when I give it gas
Old 07-05-2012, 07:07 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,173 Likes on 927 Posts
Many times the connector pins on the diagnostic link plug get corroded. A dose or two of contact cleaner usually works pretty good. In a few cases a good scrubbing with a small screwdriver or nail file maybe required.
As norfolknova suggested, go the simple route with a piece of wire to ground the test plug. If you still do not get any codes then you may have a bad PCM as andym indicated above.
Old 07-05-2012, 09:21 AM
Revmitchell's Avatar
Revmitchell
Revmitchell is offline
Originally Posted by GNR22
How much can you rev it before it starts sputtering? Does ur truck have a tach? What you're describing sounds like computer problems. I've seen this problem 2 times in the past month and the computers were fried. You could rev it up to about 2200 and it'd cut out and die even slowly revving it. And if you can on it quick it chokes right away. Sound familiar?
Reving it while parked does not create the issue. Only when Loading it up while driving down the road..I do not have a tach.
Old 07-19-2012, 01:58 PM
alenhoff's Avatar
alenhoff
alenhoff is offline
did you ever come up with a fix for it? i've got the same problem. acts like its getting ready to die and then will catch and takes off, i can't imagine it being fuel pumps since it does finally catch and go. i was thinking maybe a connection bad.
Old 07-19-2012, 02:35 PM
Revmitchell
The dealer said it needs a new Catalytic convert.
gbeach
09-15-2015 02:16 PM
bandit#47
1999 to 2016 Super Duty
08-20-2013 06:34 PM
ChronGen
09-09-2005 03:04 PM
Humam1953
11-22-2003 09:15 PM
GmanPride45
08-29-2001 12:57 PM
Quick Reply: Sputtering when I give it gas
