Satellite radio antenna
I'm in the process of removing my stock radio out of my 2012 F-250 (Sync system with Sirius satellite radio, fm radio, cd changer) and installing a Pioneer navigation system. My question is do they make an adapter that adapts the connector of the factory satellite radio antenna to fit the Pioneer connection on the Pioneer navigation units ? I would like to utilize the existing antenna if possible instead of having to run all the wiring for the antenna that came with the Pioneer.
I used my stock antenna with a Pioneer receiver ('08 F250). The stock antenna had a square plastic fitting around a circular connector. The Pioneer receiver had a circular female connector. I had to cut the square plastic from around the circular male connector on the stock antenna.
After the plastic was cut away, the antenna fit right into the Pioneer receiver.
429PI IN 75 f-100
06-14-2012 11:31 PM
JetMech07
12-10-2010 10:22 AM
