1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
7.3 vs v10 gas
Old 06-24-2012, 08:29 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
7.3 vs v10 gas
I am looking to buy a older F 250 99 or newer which engine is more powerfull the 7.3 desil or the v10 gas I will be putting a lift kit and mud tires on it and will be using it for mudding and towing how many liters is the v10 also
Thanks
Old 06-24-2012, 08:46 PM
redford's Avatar
redford
redford is online now
Received 1,565 Likes on 913 Posts
The V-10 is a 6.8L engine.
The 7.3L Power Stroke is a more powerful engine.
Old 06-24-2012, 08:55 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
What about torque
Old 06-24-2012, 09:15 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
If I got the v10 could I later put the 7.3 in it
Old 06-24-2012, 09:28 PM
dkf's Avatar
dkf
dkf is offline
V10 has more horsepower the 7.3l has more torque.
If I got the v10 could I later put the 7.3 in it.
Technically yes but it would would not be worth it IMO. Better off just trading in the V10 truck and buying a 7.3l truck. There is a lot that would have to be changed.
Old 06-24-2012, 09:33 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
The V10 comes in two forms; the 2V and the 3V.
The 2V was used from 1999 to 2004 and is rated at 305 hp and 420 ft lb (this varies slightly due to a change in 2000.)
The 3V was used from 2005 to 2010 and is rated at 362 hp and 457 ft lbs.
The 3V is still available from ford, but only in F450 and F550 chassis trucks.
The 7.3L was used for MANY years. There is also a 7.3L IDI motor that is pretty much unrelated. The 7.3L PowerStroke (that name was given to the DI turbo charged variant) was used from 1994.5 - 2003 and underwent many changes in that time.
I am going to assume you want a Superduty (Post-99) truck since you are comparing it to a V10.
The 7.3L used from 99-2003 is slightly different than that used from 1994.5-1997. Also notice a 1 year gap. No 1998 model year Superdutys were sold.
The 99-03 7.3L had many ratings over the years as things changed, but they were all in the same ballpark. The highest rating it was given was 275 HP and 525 ft lbs.
Also, a V10 and 7.3L are NOT directly interchangeable. There are many electronic changes, and the transmissions are not compatible with one another.
Old 06-24-2012, 09:45 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
Ok thanks a bunch I am looking at a 2000 with a v10 witch engine would be best suited to mudding and towing heavy loads
Old 06-24-2012, 09:47 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
How heavy is heavy? The 7.3 has more torque which is better for towing, and for slower speeds like in mud. The V10 has more horsepower which is better for high speeds.
Old 06-24-2012, 09:53 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
Welcome to FTE.
The answer to your question is yes.
A truck well siuted for mudding would be a horrible choice for towing IMO.
A truck better suited for towing heavy aint gonna make a great mudder.
You will not accomplish both with one truck IMO.
A compromize?
Old 06-24-2012, 09:55 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
Sometimes over 5000 lbs
Old 06-24-2012, 09:57 PM
Quad Racer's Avatar
Quad Racer
Knowing that, the gasser would be my choice.
Old 06-24-2012, 10:00 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
Would the gas engine be lighter than desil?
The following users liked this post:
Old 06-24-2012, 10:03 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
How does the v10 handle heavy loads
Old 06-24-2012, 10:13 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
The V10 is lighter than the 7.3L.
The V10 will tow heavy loads, but you will know is back there sooner than a 7.3 would tell you. Also in hills the V10 screams compared to a 7.3L.
Old 06-24-2012, 10:31 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
I'm not afraid of noise I don't tow that often mostly light but I would like the capability of towing pretty heavy my dad has a 02
with a 7.3 and we tow a jd big round bailer it does a pretty good job how would the gas hold up to it?
Quick Reply: 7.3 vs v10 gas
