No power to a/c clutch
Does your clutch engage manually by jumping it? The low pressure switch would interrupt to shut off the compressor.. But I cannot tell you for sure if it is supposed to have power or not, or if jumping it would turn on your compressor clutch.
There should be a fuse for the compressor clutch, if not a relay somewhere. Again, I can not tell you for sure without a schematic.
I had a friend who kept blowing a fuse every time he turned on his a/c. Come to find out there was a bad clutch. Replaced it and fine.
I believe I read that these trucks have the compressor tied to the ECM (for idle up purposes) so that makes it a little easier or more difficult, depending on your views of half empty or half full.
Which truck of yours are we talking here? And what engine?
Assuming its your '94-'96 or '97 im quite sure they ALL have high pressure cut out switches.
And only the 4.9 has a relay.
The PCM is notified when the A/C clutch sees power but does not controll it.
Power goes from the fuse to the selector on the dash panel then to the cycling (low) pressure switch then to the high pressure switch then to the A/C clutch/resistor diode in paralell with the clutch.
Your truck is using R-134 for the A/C system. It uses a High Pressure Cut-out switch. It is electrically in series with the power and the low pressure/clutch cycling switch. My EVTM shows it located near the compressor. It should be attached to the high pressure line coming out of the compressor. My EVTM CD has a crappy line drawing otherwise I would pose a photo.
Follow the Dark Green/Orange wire back to the High Pressure switch. That switch is fed from a Black/Yellow wire from the low pressure/clutch cycling switch.
