crown Vic alinement
Old 06-19-2012, 02:11 AM
mkrog's Avatar
mkrog
mkrog is offline
crown Vic alinement
What alinement specs do you guys think I should run on my 57 F100 with a Crown Vic. I.F.S.
Old 06-19-2012, 10:24 AM
manglass's Avatar
manglass
manglass is offline
I would start by using the alignment specs for the Crown Vic that it came out of.
1999-2005 seem to be:
Caster = 0.5 (+/- 0.75) degrees
Camber = 0 (+/- 0.75) degrees
Toe = -0.25 [toe out] (+/- 0.25) inches
You might want to keep Caster at the positive end of the range. Observe tire wear to determine the final toe specifications. This is a good starting point that should make the truck roadworthy but I'm sure you will have to make adjustments to get where you want (handling and tire wear). Perhaps someone who has done the conversion can advise us what settings they ended up at?
Lou Manglass
Old 06-25-2012, 01:39 PM
Romak's Avatar
Romak
Romak is offline
I took mine to a local shop and told em to set it up like a 03 Vic, dont know exactly what there numbers were but they were in spec. Ive been daily driving it for 3 years now with no abnormal tire wear in the front and great handling. now the rears I wouldnt know about because I get a little stupid with my linelock way to often an cant keep tires on more than about a 2 months.
Mike Spencer
1999 to 2016 Super Duty
05-22-2017 06:29 AM
Ken Wolkens
2009 - 2014 F150
10-24-2016 09:21 AM
Dead Cylon
15
09-26-2014 04:54 AM
jetfiremuck
Aerostar
05-26-2014 07:47 PM
psquare7575
06-24-2013 11:54 AM
Quick Reply: crown Vic alinement
