Alright y’all, what does this look like?
on
Turbo seals!
First cold day up here...-18C this morning when I woke up, block heater doesnt work. Started the truck no issues but the turbo vanes locked up and I was way way way overboosting. Drove easy, then restarted the truck and all was fine.
Oil/Coolant/Tranny temp were all 12F when the SCT turned on!
She is COLD out there! Replaced the block heater at work today so we'll see how tomorrow morning goes...supposed to hit -29C
Don't just throw a turbo at the problem unless your sure that is it. Too many times people have thrown parts at a problem and then
made noise about how expensive this engine is.
Pull the pipe and if you feel oil then pull the turbo out then check in the up pipes for oil. If you find clean up pipes then you have the issue
narrowed down to the turbo. Then it a case of do you want to do a kit or get a center section and call it good. When you open the turbo
up look to see how the unison ring and the vanes look. If you find nice parts rebuild kit will save you some money. If you find a chewed up
mess that a rebuilt turbo from Ford or a new one night be the way to go. At this point you can go same or larger.
well said about not throwing parts at it. I’m just looking at the worst (best) option in my head. Once it clears up over here in VA I’ll take the turbo out (since I’ve wanted to clean it regardless) and share my findings.
Well the best way is to use the search tool and limit the search to the 6.0L forum.
The tool is in the top blue line and you want to use advanced so that you can get
access to the options and not end up with something for a 6.7 or 6.4 or worse yet a 7.3.
Here is one thread I found with a quick search >>> https://www.ford-trucks.com/forums/1...it-to-use.html
Not sure if you can access my search results with this or not >>> https://www.ford-trucks.com/forums/s...rchid=29404503
