Need help with EEC cap on 77 F100 tank.
I am replacing the side fuel tank on a 77 F100. I ordered a new tank from LMC with the EEC vent. The tank has arrived with both holes as required for the EEC line to connect. I have ordered the sending unit to go in the side hole, LMC shipped the lock rings for both holes but did not include the vent line cap for the top hole. LMC does not sell the cap with the ventilation nipple. I have called RockAuto, Dennis Carpenter and all my local stores. No one sells this cap. Does anyone know where I can get this? My only option is to send the tank back to LMC and go with a non EEC tank. HELP.
I was stupid enough to dispose of the old tank prior to receiving the new one and the vent with it. ( stupid ) I see the rear tank on the next page, however that is a rubber grommet and not the same diameter as the one off the side tank. I have two options, find a cap for the snap ring or send it back to LMC for replacement with a non EEC tank. I find it somewhat disappointing that LMC would sell an item without all the parts.
It's available from Ford (see below), prolly other places as well. But, it isn't a cap.. it's the "fuel vapor valve."
What you are referring to is the Evaporative Emission System (ev/em).
The fuel tank has two round holes, one for the fuel tank sending unit, another for the fuel vapor valve (what you are calling a cap), also requires a seal to install it.
The fuel vapor hose routes from a nipple on this valve along the right (passenger) side frame rail, attaches to the valve on the charcoal cannister.
E7DZ-9B593-A .. Fuel Vapor Valve / Available from Ford.
MSRP: $56.30 // FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price: $30.97 / Tousley Ford: White Bear Lake MN
F6TZ-9B076-AA .. Seal-Fuel Vapor Valve to Fuel Tank / Available from Ford.
MSRP: $7.13 // tousleyfordparts.com price: $4.31.
EEC is an abreviation used by Ford in the factory shop manual for Evaporative Emission Control.
No such thing as Evaporative Emission Control / Ford terminology: Evaporative Emission System
I'm not sure why the valve is not available for this tank.
It is available from Ford (and prolly autoparts stores) and has been since 1972. The same valve was used on ALL 1972/79 FoMoCo vehicles and for other applications in the 1980/90's.
I listed the Ford part number for it and the prices.
Evaporative Emission System introduced in 1970. FoMoCo's abbreviation for it: ev/em.
The OP is calling the fuel vapor valve a cap, why he hasn't been able to find one. Because...there is no such thing!
LMC catalogs have so much wrong info, it's pitiful.
LONCO
15
11-06-2017 07:47 PM
