Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-20-2012, 01:32 PM
Steven78 Steven78 is offline
Garage is empty, add now
Steven78 is starting off with a positive reputation.
Head Gasket / Rebuild
I bought a 65 Supervan last January that had some cooling problems. After installing an aluminum 4 core radiator, new water pump, new hoses and a pusher fan it's still overheating. Just had a chemical test done and there is exhaust in the coolant, plus I need to redo the oil pan gasket anyway. I don't have the space or the skills to do a rebuild myself and have gotten quotes between $800 and $1800, all well out of my range at the moment. Any ideas for a quick fix for now? One suggestion was to seal the outside of the HG with diesel silicone and take out the thermostat. Any suggestions?
  #2 (permalink)
Old 06-24-2012, 03:55 AM
Beuler? Beuler?
  #3 (permalink)
Old 06-24-2012, 06:04 AM
tjc transport's Avatar
tjc transport tjc transport is online now
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
well, sealing the outside will not fix the exhaust gas to coolant transfer.
the only proper way to fix it is to remove the head, and have it checked for cracks and make sure it is not warped by a machine shop. once you know the head is ok, then install it with a new gasket.
this is not a very hard job for a do it yourself type of person. on a scale of 1-10, i would put it at a 3 or 4 for a shade tree mechanic, and a easy 2 for a pro.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #4 (permalink)
Old 06-24-2012, 10:09 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Amatuer Restorer
1966 Ford Bronco
gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.
This is not my recommended procedure. It should be done correctly. That said, if it is just not possible to fix correctly, you could try this. It may buy you some time. Head Gasket Fix (p/n 1111) | Products | Bar's Leaks & Rislone - Premium Automotive Chemicals
__________________
66 Bronco Half Cab, 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp, DSII ignition
  #5 (permalink)
Old 07-05-2012, 01:05 PM
Thanks for the advice!
  #6 (permalink)
Old 07-05-2012, 04:30 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
If you go that route put the original rad back till you get it fixed properly otherwise you are pretty much ruining a good rad and Im sure it wasnt cheap.
My 2c
__________________
1960 Comet mostly stock, summer DD
1979 Ranchero/Thunderbird 'Thunchero' 390 or 460 powered in the future...
1980-82 thunderbirds everywhere you look
1994 F350 IDI turbo getting a 1959 Mercury body transplant
1994.5 F250 PSD, 5spd 4" rancho on 35's
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
