zf5 swap questions
They probably went to a 12.5" disc when they raised the torque rating.
I would get the one to fit the 1989 flywheel you are using.
Because the 12.5" pressure plate will not bolt up to the '89
Gary Lewis has an epic thread going on https://www.ford-trucks.com/forums/1...-zf5-swap.html
Where he is putting one behind the 351M in his father's old truck.
There is lot's of discussion of discs, flywheels, release bearings, pilot bearings, bolt patterns, starter engagement, etc...
Oh, I forgot to add that your automatic starter will not have the proper depth of engagement for the new (old) flywheel.
now off to read that thread...........
I have a question about an engine swap, using a zf5, I am currently running a 5.8 in my 90 F 250. I am looking into buying a 460 from a 73 lincoln. I realize that the the EFI and computer wont work. this is a mud bogger and wont see street use. from my research, I can upgrade the clutch to the 460 version. but will the block bolt to the trans?
i have an external slave; the one that came off the '89 truck
can anyone confirm one way or another that an f-super duty is going to use a different clutch/brake pedal setup than a similar year f250/350?
ford has part numbers listed as this:
F3TZ-2455-B = 1992/97 F250/350 over 8,500 lbs. GVWR.
F3TZ-2455-A = 1992/97 F(Super Duty) F450 & etc.
confused?
confused?
Dan16
04-21-2015 03:30 AM
derrickmauk1003
03-26-2015 06:41 PM
White_Knight
12-18-2004 10:28 AM
