Does this look right to you?
Old 06-18-2012, 11:20 PM
AndyKotelmach's Avatar
AndyKotelmach
AndyKotelmach is offline
The clutch release bar assembly in this 1979 F100 (300 IL 6) is at an angle. Is this the way it is supposed to be?
I would think it should be straight across, level.
I think being at the angle would make it bind.
Or is this normal?<O</O
Any help appreciated.
Andy K<O</O
Old 06-19-2012, 01:39 AM
Zigmyster's Avatar
Zigmyster
Zigmyster is offline
Usually they are straight across. I'd undo the spring (to release tension) and then try to grab the cross shaft and see if you can lift it up and down and front to back. (another easier way is to get somebody to push in the clutch pedal in and out while you look at what the pivot shaft is doing) Judging from what I see, you need to replace the pivot bushings that run off the block into the pivot shaft and from there to the frame. The ends of the pivot shaft may go egg shaped after some extensive use.
Old 06-19-2012, 07:39 AM
AndyKotelmach
Thank you
Thank you for the reply.
I will check the condition of the pivot ends, but I think the engine pivot point is too low then.
The motor mounts seem to be in good condition and positioned correctly.
Thanks again,
AK
MPD56
6.7L Power Stroke Diesel
1188
12-28-2023 09:04 AM
Akhnot
01-04-2021 07:58 PM
Truckandute
08-28-2014 01:42 PM
DIYMechanic
15
06-20-2011 08:29 AM
RBP
02-29-2008 04:50 PM
Quick Reply: Does this look right to you?
