Radius arm bushing - passenger side
Old Feb 28, 2008 | 02:24 PM
RBP's Avatar
RBP
I own a reg cab 96 4x4 F150 w/5.0
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Expect this has been asked before – but I am new to this forum.
<o></o>
BLUF – (bottom line up front) the exhaust burns this bushing up!
(Seems the engineers could have done a better job than that re the placment) but any way
<o></o>
Could replace it but would just burn it up again – I expect.
<o></o>
Have wanted to put a lift-kit on the truck – (4 inch suspension)
<o></o>
Believe this would move the Radius arm bushing back far enough along the frame rail solving the problem.
<o></o>
Right or wrong?
<o></o>
Anyone made this fix or know someone who has? Did it work out?
<o></o>
What is the best suspension kit to buy to accomplish this?
<o></o>
Thx in advance!
<o></o>
RBP
Old Feb 28, 2008 | 02:33 PM
quicklook2's Avatar
quicklook2
your message was strange with all the extras.
use polyurethane bushing.
it will last longer.
Old Feb 28, 2008 | 02:40 PM
RBP's Avatar
RBP
not sure what's up or why all that junk is in the original msg
but what about a lift kit - wouldnt that fix the problem?
want one anyway...
do not want to install one just to have/find the same frustrating problem re-occur
Old Feb 28, 2008 | 03:29 PM
Josh88Ford's Avatar
Josh88Ford
Poly bushings or make a heat sheild for your cat.
Rancho, ProComp and BDS are the top for these trucks. They are all the same execpt for the shocks and coils.
Skyjacker softride coils and Nitro shocks are the best.
I have a rough country and its a pretty crappy ride, cant figure out a good shock that will last. The bolts keep comming loose
Old Feb 28, 2008 | 05:35 PM
frederic's Avatar
frederic
Use aircraft nuts. Essentially it's a nut with rounded crown with a nylon ring inserted, which locks the nut in place once torqued down.
Old Feb 29, 2008 | 04:16 PM
RBP's Avatar
RBP
heat shield for cat - how is this done?
Old Feb 29, 2008 | 04:50 PM
quicklook2's Avatar
quicklook2
use poly bushings, they will be just fine.
if you are so worried, get a piece of metal to shield the bushing.
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
54F350LNB
47
Aug 6, 2019 12:59 PM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
redman84
17
May 29, 2013 12:38 PM
stu37d
Jan 11, 2012 10:07 PM
