Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-17-2012, 07:46 AM
DPDISXR4Ti DPDISXR4Ti is offline
1991 Ford F-150
DPDISXR4Ti is gaining momentum as a positive member of FTE.
Source for M5OD Shift Cover Seals?
I'm going to do the shifter bushing replacement soon, and it only seems to make sense to replace the 3 shift cover seals at the same time (info on this pasted below). A bunch of places sell the bushing kit (I'll probably source from Allstate Gear), but I'm not finding anyone who sells the seals. Does anyone have a source for these, or is it a "dealer only" item? If the later, does anyone have the Ford part#?
Thanks...
M5OD Mazda Design Manual Five Speed Transmission
Those of you who own Ford full size or small size trucks with the M5OD Mazda design 5 speed manual transmission should have the rubber shift cover plugs resealed at your earliest possible convenience. A common occurrence with this model transmission is the rubber plugs shrinking over time and allowing lube oil to leak out of the transmission. This occurs while the vehicle is in operation, so there is less of a tendency for a puddle to develop when the vehicle is sitting parked. The result to the transmission is a lack of lubrication and damage to some very expensive gears and bearings.
  #2 (permalink)
Old 06-17-2012, 03:24 PM
Ed Bamba Ed Bamba is offline
Garage is empty, add now
Ed Bamba is starting off with a positive reputation.
I got mine from the dealer, but that was a few years ago. Someone here(?) suggested using brass freeze plugs. If you do find the correct plugs, I suggest that you install them using silicone to keep them from leaking again. Although they will eventually dry out again sometime in the future, hence the reccomendation to use brass plugs instead of the rubber variety.
__________________
1991 F150 Supercab XLT Lariat, 302 CI, M5OD tranny. All-steel custom hood with 72 Torino Grand Sport hood scoop, Night Stalker bumper cover. 92-96 side view mirrors.
  #3 (permalink)
Old 06-17-2012, 09:45 PM
1991 Ford F-150
Quote:
Hadn't read about that option. Anyone know the size and/or source?
If anyone has the Ford part# for the rubber ones, that would be great too.
  #4 (permalink)
Old 06-17-2012, 10:26 PM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
Use the freeze plug type instead of the rubber ones. They can also be picked up from Allstate Gear. That is where I got mine. Have fun.
__________________
Dark Toreador 1996 Eddie Bauer F150 Shorty, 300, M5OD, 3.55 LS
Torch Red 2005 Ranger Level II, 4.0, 5 Speed, 4.10 LS
Northern California Chapter
Quote:
Originally Posted by WilleyJoe.62 View Post
This is my line in the sand, my stand against technology, hopefully the last truck I'll ever own.
  #5 (permalink)
Old 06-18-2012, 06:53 AM
1991 Ford F-150
Quote:
Okay, good. I sent a msg to Allstate about the plugs over the weekend, so they'll probably reply back today. They seem to have the best price on the shifter bushing kit, so it'll be easy to order everything from them.
To install the plugs does the upper cover need to come out or can it be done in place?
  #6 (permalink)
Old 06-18-2012, 07:55 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
M5OD Mazda Design Manual Five Speed Transmission Preventative Measure .: Articles Have a read here.
Also broncograveyard.com can be good for parts.
  #7 (permalink)
Old 06-18-2012, 09:48 PM
1991 Ford F-150
Quote:
Originally Posted by Lazy K View Post
Yes, good article - I've seen it before and will use for reference when doing the job.
I queried one of the eBay vendors who sells the bushing kit if he sells the plugs and he asked if I need the front or rear plugs. Is this a valid question even? All I've ever read about is the three plugs, with no regard to location.
  #8 (permalink)
Old 06-18-2012, 10:09 PM
Rear plugs only.
__________________
  #9 (permalink)
Old 06-25-2012, 03:45 PM
1991 Ford F-150
Just ordered from Allstate. Total for shifter kit, 3 freeze plugs, and shipping was $37.
  #10 (permalink)
Old 06-25-2012, 04:24 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
The FORD part # is 1L5Z-7A107-AA
MSRP $9.22 each
__________________
Doug-
Ford Master Certified Parts Counterman
"Its better to have loved & lost, than to live with a psycho the rest of your life"
  #11 (permalink)
Old 06-25-2012, 06:53 PM
1991 Ford F-150
Quote:
MSRP $9.22 each
Thanks for posting - at least that'll be in here for the next guy. That said, Allstate charges $10 for all three plugs, which folks are claiming are a better option. You do need to call them up and find someone who knows what they are though - they're not listed on the web-site like the shifter bushing kit.
  #12 (permalink)
Old 07-01-2012, 12:44 PM
1991 Ford F-150
Before I go install these, here's some TranSolutions part #'s (as ordered and received from Allstate Gear)....
Shifter bushing kit Part# M50-SK $14.80
Shift top Plugs (pkg of 3) Part# TS555 $10.00
  #13 (permalink)
Old 07-04-2012, 03:27 PM
1991 Ford F-150
Got this all completed today after running into a problem with shifter fork alignment (see seperate thread w/ details). Apparently it's a better idea to do this project with the shifter in neutral rather than 1st gear.
Any way, here's a pic of what my old "bushings" looked like...
Click the image to open in full size.
The new set from Allstate is somewhat different and comes with no instructions at all. There is only one metal ring. I just put that in first in the bottom of the cup and then bushing, ball stub, bushing. I only bothered to replace one of the studs since you only need to knock one out to get the ring and lower bushing in place.
All done...
Tags
kit, m5od, repair, shifter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
