Ranger idling problem
Old 01-03-2013, 04:18 PM
Chickenguts's Avatar
Chickenguts
Chickenguts is offline
1990 Ranger 2.3L 4 cylinder.
The truck idles so rough it dies. It runs fine going down the road it just seems to "load up" at idle. I know there are hundreds of things that it could be, I just hate to start throwing parts at it. It is definitely running rich at idle.
It is one of those trucks that we have replaced a lot of parts. The scan tool said something about setting the timing??? Is there a way to set the timing?
There is no distributor, and it is the one with 2 coils and 8 plugs.
Frustrated.
Thank you for any help.
Old 01-03-2013, 07:22 PM
slc10844's Avatar
slc10844
slc10844 is offline
Post any codes you pull from the computer. If you can, do both a key on engine off and a key on engine running for codes. Check for vacuum leaks and try cleaning any deposits around the throttle plate and idle air control valve. Also inspect the air filter.
goldken51
12-13-2017 12:50 PM
1978FrankenFord
06-04-2017 07:01 PM
Aggie05
05-28-2008 05:50 PM
thom780
07-25-2004 04:50 PM
sporty boy
01-07-2004 05:54 PM
Quick Reply: Ranger idling problem
