Whats this on my vaulve covers?
Clean your old cap breather and check your air filter. Is it normal? I have not seen one of these trucks without it in factory form like yours. Also, get a new PCV for the right bank. A lot of times they go bad and cause this to happen. They are super cheap at any parts store. The PCV valve is one half of the crankcase ventilation system - the other half is the breather filter. The breather flows clean air into the crankcase through a hose on your air filter and the PCV valve lets dirty air and crankcase gases out. These dirty gases and air get sent through the engine to be re-burned for clean emissions.An old PCV valve can cause rough engine idle, blown oil seals, fouled air filter and fuel system, fumes in the passenger compartment, excessive engine part wear, and shorter oil life.
or driver side?
Because i recently bought a new oil cap breather and pcv vaulve?
If the pictures in the first post are accurate, there's an air intake on the passenger side (hose from air filter to valve cover) and a PCV valve on the other side. The PCV valve sucks out the blowby gases, fresh, filtered air replaces the volume removed as said in Post #3.
Ensure the correct PCV valve & breather cap are installed, make sure the PCV valve is actually functioning (pull it off with the engine running and put your thumb over it, you should feel significant vacuum), make sure the small air filter in the air cleaner assembly that allows fresh air into the crankcase isn't blocked.
If everything checks out in good shape and you have more blowby gases than the engine can deal with, this means your engine is well on its way to being worn out. It may last for years that way but would never pass an emissions test nor would it have optimum power output.
on
2X... what he said.
Build up of combustion gasses in your crankcase contamiate motor oil and accumulate as gum and sludge so vacuum them up!
kr98664
09-05-2016 05:26 PM
amorgeron
12-26-2006 10:04 AM
MRStace84
11-18-2003 02:12 AM
