Parking Brake Assembly for 1960 F250
Old 06-11-2012, 11:15 PM
NateTheGreat's Avatar
NateTheGreat
NateTheGreat is offline
Does anyone know where I can find a parking brake assembly for my 1960 F250? I have scoured the interwebs in search of one but can't seem to find one anywhere, new or used. I have the old parking brake assembly still but all of the ratcheting mechanism is gone. So I can pull the handle but there is nothing to catch and keep the brake engaged. I figured it would be next to impossible to find the ratcheting mechanism so I just thought I'd go ahead and buy the whole assembly. Anybody have any ideas?
Thanks much!
Old 06-12-2012, 09:29 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Should be the same one on the f350 and mayber bigger trucks as well. The big trucks and their parts get scrapped a lot, at least around here. Not too many people restore them. If Bill, aka Number Dummy could tell us what trucks have the same assembly, I would be happy to keep my eyes peeled. I think there's a guy in Austin who might be looking for a lot of the same parts too, unless he's already found them.
Old 06-12-2012, 03:47 PM
spurredon's Avatar
spurredon
spurredon is offline
I think the bigger trucks used a brake on the tranny.
What is not there on your rachet assembly. Are the notces worn off? There is just a postage stamp size piece of 3/32 inch thick or so steel and a spring that makes it work. Shouldn't be that hard to made up a little piece and bend a spring to fit. When the cables get set up and someone pulls out on the handle, there is not any tension on the little steel piece to hold it in there and it can easily be lost. It relies on the pressure of the e-brake return springs located inside the back drums to keep the tension on it. if the cables or not free to retract then bad things happen, bad things!
Old 06-12-2012, 07:40 PM
NateTheGreat
Do you have a diagram of how it should fit together? The notches seem to be deep still but there is nothing inside of the tube to engage in the notches. That's where a square piece of steel and a spring engage? A diagram or close up pictures would be great.
Old 06-12-2012, 07:44 PM
spurredon's Avatar
spurredon
Yes, the small plate catches in the notches. I will see if I can find a pic. I have the manuals but not really the skill to post without great effort.
A shop manual and a master parts catalog are worth there weight in gold.
Old 06-12-2012, 07:54 PM
NateTheGreat
Ya, I have 2 different manuals. One of them is a complete shop manual but it doesn't have the parking brake assembly in there I do need to find a master parts list, though.
Old 06-12-2012, 08:12 PM
spurredon's Avatar
spurredon
Here's an electronic version of the master parts book.
1957-63 Ford Truck & Van Complete Master Parts Catalog | eBay
Old 06-12-2012, 08:15 PM
spurredon's Avatar
spurredon
Obviously this part is not for a ford truck but part number one looks very similar to what you need. Perhaps enough to give you the idea.
1963 Parking - Corvette Parts and Accessories
Old 06-12-2012, 08:17 PM
NateTheGreat
Awesome. Thanks a bunch.
Old 06-12-2012, 09:02 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Nate, Heres a couple of pictures hope it helps!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
That little flap is shaped like an H. With the front leg of the H beveled where it engages the teeth on the shaft.
Old 06-12-2012, 09:42 PM
NateTheGreat
So after seeing what the part looked like I decided to go try and look one last time for shiggles. And what did I find? The ratcheting mechanism, at the very bottom of my toolbox! The PO must have just thrown it in there. Thanks guys! You saved me all sorts of headache and $.
Old 06-25-2012, 11:37 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I have the old parking brake assembly still but "all" of the ratcheting mechanism is gone.
"All" that causes the problemo, consists of two parts.
The two parts are his-tor-ee.
1957/60 F100/250 is the same. F350 and larger trucks are not the same.
Mechanism: The parking brake handle attaches to the lever that has notches in it.
When you pull the handle out, the lever pawl locks into a notch.
When you turn the handle to release the parking brake, the curly-que lever pawl spring causes the pawl to disengage.
The usual problemo: It's common for the spring to break, the pawl wears down to a nub. Replace both parts, problem solved.
1957/60 F100/250:
OM-2786 .. Parking Brake Lever Pawl / Obsolete
JST AUTOMOTIVE in Lebanon TN has 2 = 615-443-3086.
KLIMESH MOTOR SALES in Calmar IA has 3 = 563-562-3241.
OM-2788 .. Parking Brake Lever Pawl Spring / Obsolete
JST AUTOMOTIVE has 3 // KLIMESH MOTOR SALES has 9
GREEN SALES CO. in Cincinnati OH has 76 = 800-543-4959.
NOTE: On the end of the parking brake control outer shroud is a hole, the lever has a matching hole.
A knurled shouldered pin locks the lever in place. It may be missing if the lever has been removed from the shroud.
OM-2859 .. Parking Brake Lever Pin / Obsolete
JST AUTOMOTIVE has 11 / KLIMESH MOTOR SALES has 15
Old 12-26-2014, 11:54 AM
Doug O's Avatar
Doug O
Doug O is offline
additional question on F100 Parking brake assembly
Hi, first time user and 1960 F100 owner. Two part question similar to this thread. My parking brake handle is broken, one side mission and the other side is bent forward. I know I need to replace this and it looks like a small pin holds it to the rod. Thus far I cannot find the part # for it, as the diagram I have has part numbers for everything but the actual plastic T shaped handle.
Second question, when I twist the handle to release the brake, it does not move forward automatically. I have to push it forward toward the firewall. Any suggestions?
Old 12-26-2014, 03:43 PM
NumberDummy
Originally Posted by Doug O
Hi, first time user and 1960 F100 owner. Two part question similar to this thread. My parking brake handle is broken, one side missiing and the other side is bent forward. I know I need to replace this and it looks like a small pin holds it to the rod. Thus far I cannot find the part # for it, as the diagram I have has part numbers for everything but the actual plastic T shaped handle.
Parts catalog doesn't show that the handle was available by itself, so it only furnished with the ?
Parts catalog doesn't say, but the (sector) shaft the handle connects to was available by itself (not shown in pic), so it's possible it included the handle.
B7C-2790-A .. Sector Shaft / Obsolete ~ Call one of these sources and ask:
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
If the parking brake cables are out of adjustment (too loose), this could cause the problem with the control.
Old 12-26-2014, 05:46 PM
Doug O's Avatar
Doug O
Doug O is offline
thank you - I will call those sources. The great adventure begins. This site has great info.
Quick Reply: Parking Brake Assembly for 1960 F250
