You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
First post, so I will try to get pictures loaded later.
Bought a new 2012 F350 about three weeks ago and I LOVE IT! Tons of power, lots of features and now I am already making mods.
Just swapped out the stock orange clearance lights for the RECON smoked (nice that they came with orange bulbs to replace the stock clear) - they look awesome! Waiting on my smoked turn signals to arrive.
I also bought the Xtreme Scanning Tailgate Bar. I measured and it will fit, but WHOOPS, there's a bracket on the right side of the tailgate (between the tailgate and the bumper) that I missed. It apparently is a support bracket for the tailgate step.
Question is, what if I remove it? Will some unseen spring go BAM or is it just in case you overload the tailgate? Without removing it, the lightbar will not fit.
Showed it to the service tech at the dealership and explained my dilemma. Their initial reaction was "If Ford put it there, it must serve a purpose. I wouldn't mess with it." After looking at it, no one can see any reason why it is there. Apparently the tailgates without the step do not have the bracket and it does not appear to be anywhere near any of the moving parts of the tailgate step.
I plan to remove the tailgate tomorrow and look inside to see if I can determine any "real" function. Will post an update as soon as I finish.
Removed the bracket today - Nothing went BOOM, so that's a good thing. The bracket on the body side wasn't attached to anything. When I removed the tailgate side, I took it slow and looked in every opening I could find before I removed the bracket attached to the tailgate. I slightly loosened both bolts, then fully removed one. I then swung the bracket over and reinstalled bolt # 1. I then removed bolt # 2, removed the bracket, then reinstalled bolt # 2. All looks good. I will post some pics once the lightbar is installed.
hope the extreme light bar holds up better than the rest of recons junk for u i had one that melted the wires n blew all the fuses for trailer lights n ordered two more that wouldnt work at all n their customer service is a total joke oh n the smoked cablights will fade within the first year.. just a heads up i used to like recon but now its all JUNK
__________________
Chris, 00 Ford F350 4x4 Reg Cab 7.3 Zf6, Dual A Pillar Guage Pod Boost and Pyro.,Gearhead, Midwest Trans short throw,S&B Cold Air,GTP 38R,4" Diamond Eye, T500 HPOP, Foil Delete, Marinco Mod, Custom Built Coolant filter,DI Reg Return,HPX, black riffraff intercooler boots, AIH Delete, smoked cab lights , LED 3rd brake light, in tank mod with pre pump filter,Fuel bowl delete,238/100 SS Sticks, Comp 910s, Walboro Pump, 06 Badging,valair clutch,and More coming. STAY TUNED
