HOW CAN YOU TELL IF YOUR HPOP IS BAD
Maybe some remember but I have a hot start issue . My icp was at 247 and ipr 77% when not starting , truck would start run fine till it hits running temp then cuts off . Well have motor apart , pulled IPR yesterday and seems ok screen a tiny hole ( can barely see ) in it and maybe dished a little . Have a new one and not much diff . So i pulled intake and ERG cooler ( and for those welded cooler haters mine is in great shape and intake clean and dry ) . Got HPOP cover off and the back bolt that everybody whines about under EGR cooler exhaust fitting 8mm gear wrench gets with no problem . But back to my problem . I do have the updated cover with the channel cut into it and tried to put air into the top of the pump . I heard no leaks but did hear a bubbling sound in the oil cooler area . Anybody got any idea where to go from here ?
Pull the oil filter out Dave
If you have air coming out the Oil Filter or Girggling sound there thats normaly a sign HPOP Bad
It dont make sense to me though I would think if the Pumps Bad it would be bad Hot or Cold and not just Hot
Can you post a pick of the groove thing????
where are you putting air in ICP hole???
Them Welded Coolers are Great its just when they Dont weld them Right they create a Mess you welded yours right so it will last forever
Benny i was putting air in the top of the pump that goes in the discharge tube it feeds the IPR i think . The cover is off . There is a O ring there to and in good shape. At first i thought i had the updated cover but i don't think so now looks like the discharge tube did it but theres not a hole in the tube .
I just changed out an HPOP on a 2004 truck with a 2003 engine in it last Friday. Let me tell you, this discharge tube was definitely rubbing with the underside of the cover. When I removed the pump, and tried to spin it by hand, I must've hit a "dead spot" with it because I couldn't turn it anymore. And yes, if you hear air leaking back into the oil filter housing, the HPOP is bad. Another test to try, is to apply air pressure through a rubber tipped air nozzle directly into the branch tube with the HPOP removed. By doing this, you are essentially doing a high pressure oil system air leak check, with the HPOP and IPR removed from the equation, leaving only the rest of the high pressure oil system to check for any other issues.
Benny I can get it to my albums but that's about it . You know te groove is so perfect looking it all most looks factory cut , but it is not the same as the updated cover. I will check the rest of the system with air tomorrow and see what happens . I want to make a fitting with a hose on it to clamp on the stand pipe .
Mike can you tell me some more about this updated HPOP Updated Cover
My truck was Built on 03/28/03 When I have to dig into the HPOP should I install this updated HPOP Cover??????
What has changed with a Updated HPOP Cover???????
SCHOOLs Back in Session thanks MIKE
Dave are you refering to the Shinney spot about Middle cover and roughly 1 inch or so Long
Is that the WEAR Grove you talking about?????
Thanks for Taking the Time to Post those PICS I know its a PIA and a Job in itself to get Pics Loaded to FTE
Can I Talk you into 1 More Pic if you have time of the New Updated Cover I dont know what the Diffrence is
Thanks a TON David
Pictures by m-chan68 - Photobucket" target="_blank">http://i303.photobucket.com/albums/nn134/m-chan68/Original_High_Pressure_Oil_Pump_Cov.jpg" border="0" alt="Original_High_Pressure_Oil_Pump_Cover_For_03_ 6_0L">
I couldnt get that LINK to work Mike
Are they in your FTE Albums?????
