Head Gasket ???'s
From what I can see the gaskets come with a bore size of 4.100", which allows for up to a .100" overbore. Here are some links to support that:
Being funny!
Most of the head gaskets come with a bore side of 4.100, but you can find them with bore sizes of 4.030, etc. Prices vary. Head gaskets also come in differing materials, too, depending on how much you want to spend and the application. Also, they can vary in thickness, which can affect compression ratios. Some cylinder heads aren't compatible with some gaskets, so double check that before committing, as well.
juancho_uy
06-24-2018 02:15 PM
