What caused this?!
Old Apr 29, 2014 | 05:42 PM
RideDiesel88's Avatar
RideDiesel88
What caused this?!
I pulled my head to swap gaskets and found the old gasket is missing a part.
Old Apr 29, 2014 | 05:44 PM
RideDiesel88
And I found it in the lifter valley while cleaning the engine block.
Old Apr 29, 2014 | 05:50 PM
RideDiesel88
And I think this bent push rod is the result.
Old Apr 29, 2014 | 06:03 PM
RideDiesel88
Anyone ever see this happen? I mean it's like the head gasket was cut or punched out. I twisted the steel head gasket when I pulled the head cuz it was stuck but it would take a lot to cut the steel like that. Also could a bent push rod cause a head gasket to blow? From like an exhaust valve not opening or something..
Old Apr 29, 2014 | 07:09 PM
RideDiesel88
I'm ready to throw everything back together so I'd really love to figure out what happened in there. Thanks for any input.
Old Apr 29, 2014 | 07:42 PM
9228.bobcat's Avatar
9228.bobcat
I have seen a bent push rod tear up the gasket pretty good. I would say the push rod broke the gasket.
Old Apr 29, 2014 | 08:11 PM
RideDiesel88
Ya that's what I was thinking. So what do you think bent the push rod? The truck was running good. You would never know anything was wrong. I found coolant coming into my intake to my turbo up through my valve cover (ccv) which is right above #3 cylinder (4th push rod from front) and come to find out that piece of head gasket to seal that part of was broken off.
Old Apr 29, 2014 | 08:15 PM
9228.bobcat
Possibly coolant in cylinder.
Old Apr 29, 2014 | 08:33 PM
RideDiesel88
Ya I guess. The HG would have to blow and let coolant in cylinder then have irregular combustion and bend push rod then mess up gasket and let coolant come all the way up the crank case vent into intake to turbo?
Old Apr 29, 2014 | 09:12 PM
CPB1's Avatar
CPB1
That sequence of events does sound logical to me FWIW.
Old Apr 29, 2014 | 09:47 PM
cheezit's Avatar
cheezit
Seen lots of bent push tubes. Yes they tear up gaskets. Repleace the tube put it together and drove them
Old Apr 29, 2014 | 10:12 PM
RideDiesel88
K cool. Just trying to figure out why my head gaskets blew. Never saw puke out degas or coolant out exhaust. I'm thinking I can just throw everything together and be fine.
RustyTrustyF150
Apr 29, 2005 09:28 PM
MustangGT221
Jan 17, 2003 08:39 AM
