easy orphan fridge blinker fix
Old 06-06-2012, 10:38 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
so the other day i noticed that the blinkers needed some work so we dug in and noticed the springs behind the buttons were wasted. went to the parts store and got the wrong replacement parts. back to the parts store for the right ones and began the resto.
then the clean-up and primer
some gloss white paint
cleaned up the brass sockets
after the cleanup the brass sockets were a little loose in the housing so we pressed them back in with a extra ground wire.back together and ready for the new insides and reinstallnapa part number is LS6469 and slides right into the stock socket location. wired back up and washed the inside of the blinker lenses. installed amber bulbs just for fun and away we go
Old 06-07-2012, 09:59 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Thundersnow, thats a good idea on the ground when did you run it to? A mounting screw or to the frame, or ?
Old 06-07-2012, 06:58 PM
thundersnow70
just ran it up with the original wiring and used a self-tapping screw to mount it on the front part of the inner fender. looking back on it i could have just used the wire to tighten up the socket in the housing and then it would have grounded as it was designed. figure an extra ground cant hurt. its a wonder i never got pulled over. only had one front running light and one front blinker. on different sides. also had one low beam and one high beam out. now that its all fixed i will probably get pulled over. now i should be able to see what im about to hit................at night anyway!
Old 03-17-2013, 01:34 PM
leewiffen's Avatar
leewiffen
leewiffen is offline
How do these lights come out? Do they have a nut up under the fender? I have the same problem...thanks for the link
Old 03-17-2013, 11:09 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Very Nice job there! I am inspired to do mine. A+ on that assignment.
Evan_P
62
04-12-2019 03:10 AM
PapaBearYuma
22
04-09-2017 04:50 PM
mikey350
6.7L Power Stroke Diesel
27
04-16-2013 07:59 AM
bgalaxy67
Aftermarket Products
22
02-10-2013 11:14 AM
White-250
1999 to 2016 Super Duty
07-17-2010 01:38 AM
Quick Reply: easy orphan fridge blinker fix
